Can anyone please help.....pretty much a novice when it comes to mechanics.....i've had the usual problems....power steering hose....window switch....but still pretty happy with the car........
2001 ml320 128.000 miles
There seems to be a swirling...whirring sound.....when its ticking over....like a regular bearing type noise.....sounds like front/top of engine.....fairly slow noise like every 3 seconds....its not fan....
anyone help me out....any known problems around here.....
Also just had transmission fluid changed......now seems to be very slight leak /drivers side front just behind engine.....can barely see underneath but looks like there is a drain plug there/leaking....
is this for transmission......
Thank You.....
