Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 03-08-2008, 11:47 PM   #1 (permalink)
Date registered: Mar 2008
ML430 misfire
Hi team
I have a 2000 ML430 done 130k kms (about 80k miles). Recently it has developed a misfire in cylinders 5 and 7. It starts on 8 cylinders, although at idle runs a little rough, then after a minute or so develops the misfire, and shuts down fuel to the 2 cylinders in question.
So far the technician who is trying to locate the problem has changed the sparkplugs, coils, and HT leads. He has checked the compressions, all of which are well within tolerances, valves, lifters etc. It doesn't rattle in the top of the head so we have largely ruled out a mechanical issue.
Has anybody encountered a similar problem or has a suggestion of where we should look next?
Thanks in anticipation.
nztankman is offline   Reply With Quote
Old 03-08-2008, 11:55 PM   #2 (permalink)
eric242340's Avatar
Date registered: Nov 2007
Vehicle: S320
Originally Posted by nztankman View Post
Hi team
Clean the fuel injectors and replace the fuel filter.
ERIC
eric242340 is offline   Reply With Quote
Old 03-09-2008, 01:19 AM   #3 (permalink)
Thanks Eric
Should of added that we have done the injectors - not sure about the fuel filter, will check with my techo.
Cheers
Old 03-09-2008, 05:39 AM   #4 (permalink)
eric242340's Avatar
Vehicle: S320
Thanks Eric
Cheers
The missfire only happens on the same two cylinders? Was this missfire on the same cylinders before the coil/spark plug change?
Old 03-09-2008, 01:10 PM   #5 (permalink)
Thanks Eric
The misfire was on the same two cylinders (5 & 7) both before I changed the sparkplugs, coils and HT and after. The injectors have been cleaned, they were injecting the correct amount of fuel but some had an irregular spray pattern.
Thanks
Old 03-10-2008, 04:34 AM   #6 (permalink)
eric242340's Avatar
Vehicle: S320
Swap the injectors from 5 and 7 with 1 and 2 then see if the missfire moves to 1 and 2 or is it still 5 and 7.
need help w/ misfire Maksiu420 W124 E,CE,D,TD Class 3 11-27-2007 03:42 AM
ml430 misfire kelland General Mercedes-Benz 5 05-28-2007 03:51 PM
Misfire! Help... ScrapingScrap W126 S,SE,SEC,SEL,SD,SDL Class 13 03-16-2006 10:20 AM
Will 2001 Ml430 transmission work in a 2000 ml430? orlandotrader W163 M-Class 3 02-24-2006 05:31 AM
misfire alexbonser W201 190E, D-Class 2 02-08-2004 01:29 AM
