» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 03-05-2008, 02:09 AM   #1 (permalink)
C-Rod
C-Rod's Avatar
Date registered: Oct 2002
Vehicle: 2006 ML 350.
The centre section............
which houses the AC controls, l'm trying to remove the wooden bezel around it.....Does it have to be done from the back, or will it pull off from the front ???? Does removing the radio make it any easier....Thanks in advance........
1999 : Black Opal ML 430 : 125,000 KM (traded-in)
2002 : Bordeaux ML 55 : 130,000 KM (traded-in)
2006 : Silver lridium ML 350 : 35,000 KM
Iriduim Silver/ Ash Grey Leather, Premium Package, Ambient Lighting, Parktronic, Navigation, Driver's Side Memory, Heated Seats, Electrically Folding Side Mirrors, CD Changer, Ipod-kit, Power/Telescope Steering Wheel, Sunroof, Homelink, Privacy Glass.
C-Rod is offline   Reply With Quote
Old 03-05-2008, 09:44 AM   #2 (permalink)
Drew_ML
Date registered: Sep 2007
Vehicle: W164 ML320CDI
Carlos, you have to pull it off from the front. There are two clips/latches that you have to release at the lower two corners (left and right) of the wood panel. Reach underneath the "ledge" and you should be able to feel something there that you can lift up on and pull towards you. From what I recall, the panel should then come out.
You have to remove that panel to get to the COMAND system actually, so you can't remove the radio to help you
If you have to remove the ashtray, slide it open, and there are torx screws that you can remove and then slide the tray out. You'll have to maneuver the tray open/close in order to wiggle it out between the two grab handles.
Drew_ML is offline   Reply With Quote
Old 03-07-2008, 02:13 AM   #3 (permalink)
C-Rod
C-Rod's Avatar
Thumbs up Thanks "D"............
lt worked like a charm...........l have removed all the wooden pieces and replaced them with the graphite-looking bezels..lt looks much better with the aluminum pieces on the doors...."more sporty"...Thanks again..........as always.............
Old Timer Centre Heffalump General Mercedes-Benz 0 12-20-2007 04:08 AM
help with these centre caps please... samm W124 E,CE,D,TD Class 1 11-11-2007 03:10 AM
Centre console Adnan633 W140 S-Class 2 07-23-2007 04:16 AM
G Centre Munich Maxwell Smart G-Class 8 04-09-2006 04:22 AM
Centre diff. Scott(uk) G-Class 4 09-08-2001 02:21 AM
