» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 02-17-2008, 05:43 AM   #11 (permalink)
Date registered: Oct 2007
As per the 2008 Owner's Manual
The "lost" of this feature happened to me also but here is how to recover !
Check your Owner's Manual ( 2008 CDN 320CDI ):
"The exterior mirror on the front-passenger side moves into the parking
position as soon as you engage reverse gear.
Make sure that the parking position for the exterior mirror on the front-passenger side is stored with the memory function.
(My note : you must adjust the exterior mirror on the front-passenger side
the way you wish it to be in )
Make sure that the key is in position 2 in the ignition lock.
Press button for the exterior mirror on the front-passenger side.
Engage reverse gear.
The exterior mirror on the front-passenger side moves to the stored parking position.
The exterior mirror on the front-passenger side moves back to its original position:
as soon as you exceed a speed of 10 km/h
about ten seconds after you have disengaged reverse gear
if you press button for the exterior mirror on the driver's side"
Hope this helps.
billjet is offline   Reply With Quote
Old 02-18-2008, 11:20 AM   #12 (permalink)
Date registered: Dec 2007
So do I store the passenger side mirror in the reverse tilt down position in memory?
turbohardtop is offline   Reply With Quote
Old 03-13-2008, 06:18 PM   #13 (permalink)
MY2008ML350's Avatar
Date registered: Mar 2008
You can also refer to the MB online manual:
M-Class Interactive Owner's Manual [Start]
MY2008ML350 is offline   Reply With Quote
Old 05-06-2008, 07:49 PM   #14 (permalink)
Date registered: Apr 2008
Vehicle: ML550
I tried this on my ML550 today and couldnt get it work. Has anyone else got it to work on an 08? Can someone give some additional detail? Does the dealer need to do some programming first?
Hope this helps.
Mamba003 is offline   Reply With Quote
Old 05-07-2008, 04:23 PM   #15 (permalink)
I have an 08 ML and it works! Maybe only for Canadian models?
Does the Passenger Side Mirror Tilt Down in Reverse BKHammond W204 C-Class 13 10-16-2007 08:51 PM
Side Mirror Tilt in Reverse BKHammond W164 M-Class 18 08-13-2007 09:30 AM
What MY did the reverse = passenger side mirror tilt begin? J-bird W163 M-Class 9 01-05-2004 08:36 PM
Reverse Tilt Mirror Question. Darkmann W163 M-Class 15 10-10-2002 12:18 PM
Is my right rear view mirror supposed to angle down when i'm in reverse? Forrest R170 SLK Class 4 03-23-2001 11:34 AM
