Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 02-01-2008, 05:16 AM   #1 (permalink)
Date registered: Dec 2006
Question ML164, VIBRATION THRU FLOOR
HAVE AN 06 ML320 CDI WITH LESS THAN 6K ON IT AND EVER SENCE NEW I'VE HAD A HARMONIC VIBRATION THRU THE FLOOR AND CENTER CONSOL AT HIGHWAY SPEEDS NOT A BIG VIBRATION JUST SUTTLE BUT CONSTANT. REALLY ANOYING AS IT MAKES YOUR LEGS TIRED AFTER A FEW MILES. DEALER SAYS ITS NORMAL WITH AIRMATIC SUSPENSION SYSTEMS?
ANYBODY HAVE EXPIERENCE OR CAN SHED SOME LIGHT ON THIS SUBJECT?
ELENA is offline   Reply With Quote
Old 02-01-2008, 06:06 AM   #2 (permalink)
Vehicle: ML500, E320 4Matic
My ML500 with Airmatic does NOT have such a vibration. What your dealer said in incorrect or you misunderstood them. I would insist that they find what it is and correct it. Could be an exhaust pipe not quite aligned correctly or a trans maount that is defective or not installed correctly.
sosh is offline   Reply With Quote
Old 02-01-2008, 07:29 AM   #3 (permalink)
thinkman's Avatar
Date registered: Oct 2004
Vehicle: 2008 GL450, 2003 C240, 2005 SC430, 2003 AUDI A4, 2005 SONATA
Send a message via AIM to thinkman
take it to a different dealer!
2008 GL450 Black/Macadamia, Premium 2 package, Full leather package, DVD entertainment system, Running boards, Voice Control, Trailer Hitch, 6 Disc CD-changer, Illuminated Door Sills, Ipod Integration, Keyless-Go, SLEEK TRUCK! HAULS ASS!
thinkman is offline   Reply With Quote
Old 02-01-2008, 07:36 AM   #4 (permalink)
Date registered: Dec 2007
I have no vibration in mine whatsoever. My airmatic rides smooth as silk. I had a similar problem in a vehicle a few yrs ago( non-Mercedes) and it turned out to be the driveshaft was out of balance. It also might be the tires not balanced properly from delivery as you dont have enough miles on it now to really be worn out of balance or perhaps you have thrown off a wheel balancing weight
1980 450sl traded in
1983 380sec sold
1989 300se traded in
2002 ML320 sold
2008 ML320CDI /Full load (inc air susp) minus rear entertainment/ Pewter Silver Black leather
Vernl is offline   Reply With Quote
Old 02-01-2008, 08:36 AM   #5 (permalink)
Date registered: Aug 2007
Vehicle: 2008 ML 320CDI
At 6000 miles, the tires should be set and a rebalance is in order. It looks like you don't drive very much, so keep in mind that some tires will take a few miles to smooth out after the car has been parked for some time. The colder the weather the more time it will take. I would put my money on a balance problem. My air suspension ML is very smooth. Go straight to another dealer and don't take no for an answer!
wadesalot is offline   Reply With Quote
Old 02-01-2008, 10:05 AM   #6 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
Agreed, but try using a specialist high-end tire/wheel shop for the balance job. They can do it while you wait.
Often a balance needs to be redone on a new setup after intial balance.
S.
2006 ML350 white/ash
2008 C300 Sport mars red/black
2004 986S seal gray metallic/black/black
MB-SV is offline   Reply With Quote
Old 02-02-2008, 04:39 AM   #7 (permalink)
VIBRATION ISSUE
THANKS ALL FOR THE INPUT. FURTHER ,I HAVE HAD THE TIRES BALANCED TWICE IN AN EFFORT TO ELIMINATE THE PROBLEM TO NO AVAIL.
I'VE GONE PAST THE DEALER NOW AND AM NOW DEALING WITH THE MB FACTORY REPS HERE IN AUSTRALIA, SAME RESPONCE FROM THEM. REALLY NOT IMPRESSED WITH THEIR EFFORTS TO RESOLVE THE PROBLEM. ANY FURTHER INPUT WELCOME
Old 02-02-2008, 11:06 AM   #8 (permalink)
I would keep going up the line and start documenting my dissatisfaction and asking for MB responses in writing. What they are telling you is just not correct. After rereading your original post, sounds more like a driveline problem, and these can be tedious to resolve. Since they say "they all do it", I would demand they demonstrate that with any other vehicle on the lot. At some point, I would stop trying to resolve it nicely and make a total peat out of myself to the zone folks and MB in Germany.
Old 02-02-2008, 11:47 AM   #9 (permalink)
MB-SV's Avatar
What wheel and tire combo are you running on the ML in question?
Old 02-03-2008, 05:34 AM   #10 (permalink)
Stock 18" mags as delivered
Floor Mats available srsomasundaram W126 S,SE,SEC,SEL,SD,SDL Class 4 05-12-2006 08:56 PM
Floor Mats BenzMama13 W126 S,SE,SEC,SEL,SD,SDL Class 10 04-05-2005 10:37 AM
floor mats Garbo1954 W210 E-Class 4 10-26-2004 06:10 PM
Floor Jack Help... Vik W163 M-Class 6 10-15-2004 05:47 AM
OT. NE1 paint their garage floor with Griots floor paint or other type of paint ? DaveS R170 SLK Class 6 07-31-2003 06:40 PM
