Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 11-09-2007, 06:38 PM   #1 (permalink)
digimark's Avatar
Date registered: Mar 2006
Vehicle: (deceased) 99' ML320, new '07 ML320 CDI, '06 Mini Cooper S.
Questions about roof-mounted cargo boxes and baskets.
I recently bought a pair of Yakima Lowrider crossbars/towers/locks for my '07 ML320. Now I'm looking at purchasing either a cargo box or a basket/net to mount on it for trips. It's kind of off-topic to ask about it here (unless of course you think it isn't!) but I'm hoping for a referral to a website or FAQ resource that talks about selection and usage. Specifically, when to choose a cargo box over a basket, how things get secured down so that they won't blow off/away at 70MPH or better, and otherwise what to expect when using them. My family's traveling out of town for Thanksgiving, and I was thinking of using something to store extra bags and luggables up there (subject to the total weight limit, of course.) Anything that will help me increase my confidence would be wonderful.
Thanks in advance for any pointers, URLs or insight. -Gary
Extra points if someone can tell me whether Thule's bags-that-fit-in-the-cargo-box system is
more useful then pretty.
digimark is offline   Reply With Quote
Old 11-09-2007, 10:46 PM   #2 (permalink)
Date registered: Dec 2003
Vehicle: ML 350
Well you're lucky.
I went through this very query about a year ago and opted for the Yakima Rocket Box. It can hold 150 pounds of stuff; it looks sleek; I do a lot of freeway driving; it has nylon straps which can secure whatever you're hauling; and the ONLY problem I ever had was forgetting it was on top when I entered a very low parking structure.
It's absolutely incredible the amount of "stuff" you can haul in a ML with the rear seats folded down and your Rocket Box on top. I heartily recommend you look no further!
smarten is offline   Reply With Quote
Old 11-12-2007, 02:17 AM   #3 (permalink)
digimark's Avatar
Thanks for the reply. In your estimation, would something like the RocketBox 16 interfere with the liftgate on the back of the 2nd Gen M-Class? I see Yakima also has a SpaceCadet 15S which is shorter/wider.
Do things tend to fly around inside the roof boxes, or is it expected that we should tie things down with strapping of some kind?
If its not too embarrassing to share, what happened when you drove under the parking structure? -Gary
Old 11-12-2007, 08:58 AM   #4 (permalink)
Vehicle: ML 350
The box fits. When you're mounting the crossbars [which must be 36" apart], you have to come as close to the front of the vehicle as possible. That way when the lift gate opens, it clears the roof box. If you go wider, you'll have a problem reaching distant portions of the box without a step ladder. Also by going with the Rocket Box, there's still room left over adjacent to the box so you can mount something else.
I haven't experienced items "flying around" inside the box even without strapping. It just hasn't been a problem. But the box comes with two straps just in case.
When I drove under the parking structure the box got squeezed down [it did not break] and then popped back up inside the garage [where the roof was higher]. Basically we had to remove the box inside the garage in order to get out. Actually no harm, no foul, but it could have been a disaster.
Don't know where you're located but if I were you I'd start scouring over craigslist looking for a slightly used box. If you're lucky, you'll be able to save a bundle!
Good luck!
Old 11-12-2007, 04:08 PM   #5 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
Another reason you'll want the box forward is that you don't want to cover your sat radio antenna.
Kent Christensen
Albuquerque
Any R Class Owners Using a Roof Top Cargo Carrier? manwagon W251 R-Class 22 11-18-2008 06:10 PM
Need info on large roof cargo carrier. benzenvy W210 E-Class 3 05-06-2007 02:50 PM
Roof mounted cargo carrier IndyML500 W163 M-Class 4 05-27-2004 12:37 PM
THULE roof rack and cargo box rdabbous G-Class 2 10-28-2002 10:51 AM
Roof racks - cargo container options Gustav M. W163 M-Class 0 04-22-2002 10:47 AM
