Does any know how much it should cost for the phone completer kit and installation in a 06 Ml350. I have tele-aid and understand that once installed I need the wireless adapter for the puck to enable bluetooth. My dealer In Massachusetts told me he thought it would be about $2600 for completer kit and install the wireless adapter is an additional $420 as found on AWS. Sounds like a lot to me.
the prices quoted are about right (although there are places that sell them a bit cheaper if you look around. the main thing you need to look for is if you have the phone modules present or not. look in your center console, specifically at the top section. there you will see either a raised plastic plug with a cover over it or the just a flat section with what looks like a cut-out for a plug...
if you have the plug then all you need is the wireless adapter. otherwise its the adapter and the completer kit.
