Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 08-09-2007, 05:32 PM   #1 (permalink)
Date registered: Jul 2007
Trailer wiring options?
2007 ML350. Does anyone know our if there is a plug in trailer wiring option? I can install a universal wiring kit, tapping into the factory wiring, but would rather stay away from that.
kontradictions1 is offline   Reply With Quote
Old 08-10-2007, 03:52 AM   #2 (permalink)
Date registered: Mar 2007
Vehicle: ML350
if you look in the r-class forum there is a thread discussing this issue. you can tap in aftermarket harness but because if the lighting supervisor circuit you are limited by the size/number of bulbs on the trailer: too many and the vehicle will throw bad bulb warnings.
fortunately all MB suvs (ML/GL/R) support a factory wiring harness option. you will need to get the trailer harness kit for the GL and you will also need to have the dealer flash your rear SAM for trailer function.
rob13572468 is offline   Reply With Quote
trailer wiring cannoncrzy Audio & Telematics Forum 0 04-19-2007 06:24 PM
Please help with Trailer Hitch options for 300SDL Benz4Time W126 S,SE,SEC,SEL,SD,SDL Class 1 07-27-2004 11:31 AM
Trailer Wiring SBR G-Class 8 07-25-2003 01:41 PM
02 G trailer wiring Brent G-Class 7 08-13-2002 04:03 PM
Still need help w/trailer wiring Guest (MBNZ) W124 E,CE,D,TD Class 0 07-22-2002 01:20 PM
