» Site Navigation » Other Sites
» Network Links
08-08-2007, 11:00 AM
#1 (permalink )
Date registered: Aug 2007
ML 63 oil leak
We have an '07 ML 63 with a tenacious oil leak that so far has defied repair. It apparently is in the oil line from the oil cooler, at the fitting into the block\oil pan (I haven't been allowed back into the shop to see exactly how it is attached, or where). I understand there are similar problems in cars in Salt Lake, Phoenix and Sacramento.
I searched briefly on this site regarding prior posts on this subject, but found nothing. Any thoughts about this issue, or possible repairs?
08-09-2007, 03:31 AM
#2 (permalink )
Date registered: Jan 2007
Vehicle: 2002 honda civic
I believe there is a DTB on this issue. i cant remember though but I have seen several repairs of the oil lines on the 164.
Thread Tools Display Modes Linear Mode
Similar Threads Topic Author Forum Replies Last Post Help Oil leak with smoke. What oil grade/weight/brand. Thank You rcs hawaii R129 SL Class 3 08-11-2007 11:35 PM Wiring loom - insulation falling off, water leak, oil leak sjc123456789 W124 E,CE,D,TD Class 3 02-10-2006 11:24 AM oil leak... motor honey?...leak stop? b2d W123 E,CE,D,CD,TD,TE Class 1 04-11-2005 04:07 PM My car is in the shop...Oil leak, windshield washer leak, and screw came off. chanm W163 M-Class 3 05-23-2003 07:21 AM My 96 S320 to have a cracked engine block gasket, which cause a oil leak .All oil changes (more)... Guest (MBNZ) W140 S-Class 2 04-19-2002 02:34 PM
