Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 07-05-2007, 03:05 PM   #1 (permalink)
Date registered: Jul 2007
Steering Column Defect .....Anyone else?
I just took my '06 ML350 into the dealer for a grinding noise when I turned the steering wheel from side to side after the ML had been driven for about 1 hour. (Warmed up). The shop foreman said the noise was coming from the steering column sleeve. There is a rubber insert that's causing the problem. He said that I am not the 1st to have this defect, in fact, Mercedes has redesigned a new part for replacement. Just wondered if any on else has had this problem ?
dwalla is offline   Reply With Quote
Old 07-05-2007, 08:14 PM   #2 (permalink)
Update on Steering Problem
Replaced upper steering shaft bearing and housing. All is well for now!
Old 07-06-2007, 02:42 AM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
havent seen any ML's in our shop for that complaint
Streetglower is offline   Reply With Quote
Old 07-10-2007, 07:27 PM   #4 (permalink)
Vehicle: 04 C230K/07 ML350/07 CLK 350
There is a TSB on this and my dealership had mine serviced last time when my car was in the shop. But they have to order the part in though because the shop did not have it in stock. All seems well now.
proudowner3 is offline   Reply With Quote
Old 07-11-2007, 08:50 AM   #5 (permalink)
I have a 07 ml350. I notied at around 11K there was something amiss in the steering column when hitting bumps. If you hit a row of road markers just right, you could really get it going. It turned out to be a bearing/bushing in the column. Dealer fixed it right under warranty. That was the first and only issue so far.
Ken
kernith is offline   Reply With Quote
Old 07-12-2007, 01:19 AM   #6 (permalink)
Date registered: May 2004
Kenith, when you hit one or two bumps, did it feel like something was slightly loose in the steering and you maybe felt a bump a little too much in the hands? We may have this problem.
atabibia is offline   Reply With Quote
Old 07-12-2007, 01:19 AM   #7 (permalink)
Ken
Old 07-12-2007, 01:20 AM   #8 (permalink)
Bizarrely, I had exactly this problem in my 2000 E early in its life. Can't remember what they did, but it was reasnably major repair. No problems since.
Old 07-12-2007, 08:33 AM   #9 (permalink)
Yes, it felt like something loose in the front end somewhere. I have felt this same feeling on old cars with worn tie rods. But those cars have other problems with tracking. Of course the ML350 was tracking perfectly. I also experienced this same type of feeling with my old 560 SEL after the turn signal switch was replaced. I took it back and they could not find the trouble. I put up with it for a while, then I figured it had to be something done while replacing the switch. It was. I found they did not get the air bag in just right and it was causing the feeling. I realigned the air bag and the problem went away. I mentioned this to the dealer, but they reported the trouble was with the bushing and bearings in the column itself. They fixed it.
The only way I know to describe it is there is a feeling in the steering wheel from feedback from bumps. But it does not move the wheel or change the tracking, just feels like something loose in the system.
Hope this helps,
Ken
Old 07-12-2007, 11:50 AM   #10 (permalink)
Hope this helps,
Ken
Very helpful thanks. This is exaclty how I would describe our problem, which I first felt after the instrument panel had to be replaced (problems w/ fuel guage).
steering column bishopjr W202 C-Class 3 09-08-2006 04:26 PM
Buzz in steering column GregW / Oregon W164 M-Class 12 06-21-2006 07:03 AM
Squeaky Steering Column won't go away olivengco W210 E-Class 4 12-19-2004 09:15 AM
steering column gdbmj W126 S,SE,SEC,SEL,SD,SDL Class 1 07-20-2004 09:04 AM
Steering Column sklas W126 S,SE,SEC,SEL,SD,SDL Class 3 06-20-2004 12:44 AM
