Brake Lights Wont Go Off! - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 05-23-2007, 06:54 PM Thread Starter
VJ1979's Avatar
Date registered: Jul 2006
Vehicle: 2001 CLK 55 AMG - CAPRI BLUE/TWO TONE AMG INTERIOR - 2007 ML 350 AMG APPEARANCE PACKAGE
My brake lights are constantly on. Im guessing theres a switch or solenoid that went bad or is stuck. I searched near the pedal and found no such switch/solenoid. Anybody know where the switch is located???
thanks!
VJ1979 is offline
post #2 of 9 (permalink) Old 05-24-2007, 02:37 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
some of the newer MB dont use brake light switches. its a possibility you have a faulty rear sam as that controls the brake lights.
Streetglower is offline
post #3 of 9 (permalink) Old 05-24-2007, 08:23 AM Thread Starter
VJ1979's Avatar
whats a rear sam? where is it located?
thanks!
VJ1979 is offline
post #4 of 9 (permalink) Old 05-24-2007, 09:00 AM
Date registered: Mar 2007
Vehicle: 2007 Alpine Rain/Ash ML320 CDI
At this point I would simply return to the dealer and have it fixed under warranty. Maybe a fuse could cause it. Auto electric circuits can have all kinds of loops. Make sure everything is working.
CJzBenz is offline
post #5 of 9 (permalink) Old 05-24-2007, 07:41 PM
Vehicle: 2014 ML350 BT
Quoted: 8 Post(s)
I had a similar problem on a fairly new vehicle (not a Benz) many years ago... it was a stuck relay. I unplugged it from the fuse block and reinserted it. The problem went away never to return. I don't know if the ML uses relays for the brake lights, but it's worth checking.
EricM is offline
post #6 of 9 (permalink) Old 05-30-2007, 04:53 PM
Vehicle: 2005 C230K Sport Coupe 6-speed! And now a 2011 GLK 350 4Matic in Palladium Silver!
If the lights are indeed controlled by the SAM, then ther would still have to be a switch of some type to tell the SAM that the pedal was pressed.
Whosdis is offline
post #7 of 9 (permalink) Old 05-30-2007, 06:20 PM
Quoted: 4 Post(s)
thanks!
rear sam is the signal and aquisition module, it basically controls certains components. brake lights, fuel gauge, central locking, etc...
post #8 of 9 (permalink) Old 05-31-2007, 06:04 PM
Oh, for sure. But something still has to tell the SAM that the pedal was pressed.
Whosdis is offline
post #9 of 9 (permalink) Old 06-01-2007, 02:57 AM
Quoted: 4 Post(s)
if I remember correctly, one of the BAS sensors detects the pressure on the pedal and in turn sends signals to the rear sam which in turn activates the brake lights. i would have too look it up though
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
    My Bottom Brake Lights Wont Come On But The Third Light Does? DETANE W163 M-Class 7 04-17-2007 03:45 PM
    HELP...My Fog Lights Wont go Out! gemee W124 E,CE,D,TD Class 1 03-02-2007 06:24 AM
    Lights come on but wont start.... 240DZL W123 E,CE,D,CD,TD,TE Class 11 03-08-2006 06:21 PM
    lights wont go off 1stMB W201 190-Class 5 09-21-2004 07:21 AM
    Help lights wont turn off samsongee C208/A208 CLK-Class 1 07-08-2004 02:54 AM
