Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 02-16-2007, 05:36 AM   #1 (permalink)
ARIDAN's Avatar
Date registered: Nov 2006
Vehicle: 2007 ML350 Pewter/Black
Low tire pressure warning and can't shift into Park
Hey guys, I have a question which I hope can be answered relatively quickly. I'm currently in Chicago on a business trip and last night I received a call from my wife saying she is having problems with the ML.
It started when she was on her way home from work last night. It began with a red dash lights of "Low air pressure" warning. She was not aware of any flats or anything of that sort so she continued with her drive home. When she got to the driveway, she wanted to put the car into park so she can get the mail but the car simply would not shift into park!!! She then proceeded up the driveway and into the garage, but again, nothing, the car won't park. After a few failing attempts she resorted to turning off the engine while in Drive.
I had her call MB roadside assistance. A tech came out and said it looks like a transmission problem but he can't diagnose it because he doesn't have the proper tools to do that. He recommended taking the car to the dealership for further inspection.
Has anyone heard or experienced of such transmission problems?
Is it possible that the tire pressure and the transmission problems are related in anyway?
This is our first MB. It's a 2007 with less than 2000 miles on it. This is CERTAINLY not something that I expected to have with a brand new MB!
TIA.
2007 ML350 | Pewter/Black | P1 Premium I | Heated Seats | 6-Disc CD Changer
2007 INIFNITI G35 Sedan S
ARIDAN is offline   Reply With Quote
Old 02-16-2007, 07:07 AM   #2 (permalink)
BigKutta's Avatar
Vehicle: 2006 ML350
I got the same air pressure warning last weekend. All the tires looked fine but when i checked the air, one was in the 20's. With closer inspection i found a thick metal wire sticking out of the tire. So it detected a slow leak. However, there was no issue with shifting into park. I do not think these are related. Have you done the tranny SW update? Matbe that will fix it, otherwise a new tranny from MB may not be a bad thing
2006 ML350 Pewter/Ash, Trim Pkg, Sunroof Pkg, Entertainment Pkg, NAV, Heated Seats
_________________
2001 BMW 325i, Leather, Premium, Heated Seats, CD changer
BigKutta is offline   Reply With Quote
Old 02-16-2007, 08:08 AM   #3 (permalink)
Vehicle: ML500, E320 4Matic
Transmission problem is most likely not the transmission itself but the shifter solinoid mechanism. Seems kind of radical to suggest a transmission replacement. Could even be cold/ice related.
sosh is offline   Reply With Quote
Old 02-17-2007, 08:33 AM   #4 (permalink)
Date registered: Dec 2004
Vehicle: ML-500, BMW 330xi
ARIDAN : I had a similar problem except that my transmission was stuck on PARK. Whenever I tried to shift there was a red warning flashing in the MFC: DRIVE DIRECTLY TO GARAGE WITHOUT CHANGING GEAR. The Dealer sent a technician with a laptop to perform a “RESET” which enabled him to drive the car to the Garage where they replaced the ISM Control Module. With this new module, the transmission became much smoother and silkier. All the rough shifting and jumping which I experienced before have disappeared.
The ML-500 have this safety feature. After switching the engine off and opening the driver door, the Transmission will shift to Park automatically if the driver did not engage the Shifting Stalk. I do not know whether this feature is valid also for the ML-350. If it is, it would be interesting to find out whether Park will engage through this back up procedure.
jean7of9 is offline   Reply With Quote
Low Tire Pressure and Mileage fh8510 R171 SLK Class 7 06-28-2006 09:10 AM
taking down tire pressure for 4x4 ing. could you do that on a low profile tire? blau The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-06-2006 02:49 PM
Has Anyone Ordered the Tire Pressure Loss Warning System?? NewMB R171 SLK Class 15 08-05-2005 05:41 PM
Tire Pressure Warning System Jörg W163 M-Class 6 03-22-2002 05:39 AM
Park Brake warning Light and Low fuel warning light Ameet Patel R170 SLK Class 3 03-21-2001 04:28 PM
