Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 11-03-2006, 02:59 PM   #1 (permalink)
Date registered: Oct 2005
Vehicle: 2006 ml350
HID Conversion Kit??
Hi, I was just wondering if anybody had changed their halogen bulb to a aftermarket HID conversion kit and if so how did it result??
I am also wondering what is the temperature for the standard bi-xenons..is it 4300K or 6000K.
any input would be appreciated thanks.!!
juank350 is offline   Reply With Quote
Old 11-03-2006, 03:51 PM   #2 (permalink)
~BANNED~
DUTCH's Avatar
Vehicle: 2000 G500 NMLE & 2007 ML320 CDI
There's now an MB Lighting Forum on another website. Email me for particulars, as the filters here won't allow it.
gwagen@bellsouth.net
DUTCH is offline   Reply With Quote
Old 11-05-2006, 08:36 AM   #3 (permalink)
Date registered: Oct 2006
The standard temputure that the ml's ship with is 4300K
btshep is offline   Reply With Quote
Old 11-05-2006, 10:11 AM   #4 (permalink)
Vehicle: ML500, E320 4Matic
Be careful of the aftermarket conversions, many are not DOT approved, you will not have auto leveling and thats illegal in many places and FYI 6000 gives off far less usable light than the 4300s that MB uses. You can also create electrical problems and cause much damage as the current draw could be much higher than the system was designed for.
sosh is offline   Reply With Quote
Old 11-06-2006, 11:09 AM   #5 (permalink)
Date registered: Jun 2006
Had great luck with the carlab kit. They advertised around here. Plug and Play rugged and simple. No modifications required at all. Hardest part was getting behind the headlight of my E500
05E500 is offline   Reply With Quote
Old 11-06-2006, 01:12 PM   #6 (permalink)
Vehicle: 2006 ml350
Did you have to take to the dealer to change the ECU to Xenon or there was no error message??
Old 11-06-2006, 06:19 PM   #7 (permalink)
Vehicle: ML320 CDI
I've had bi-xenon lights installed as an original option on a car that is now 4 years old. The first year I had numerous cars flash their lights at me thinking that I had my bright headlights on, but HIDs are now more common and that does not happen. Every time I use the lights, the automatic leveling occurs with the lights moving up and down at first to get the angle correct. I don't understand how that kind of sophistication can be found in an aftermarket plug in conversion kit. I've gotten blinded by the poor qualities of the aftermarket lights on cars (they obvously weren't standard on these cars), and other drivers have also, and those drivers then get mad at my lights that are well controlled and legal. Definitely purchase the lights as an option on your new car, but don't fool yourself into thinking an aftermarket purchase will work the same.
hawbottom is offline   Reply With Quote
Old 11-16-2006, 01:54 PM   #8 (permalink)
Date registered: Nov 2006
how much did the full Mercedes OEM upgrade cost?
hi hawbottom
Can I ask how much did the full Mercedes OEM upgrade cost?
tonecontrol is offline   Reply With Quote
Old 11-16-2006, 05:38 PM   #9 (permalink)
Vehicle: ML320 CDI
The lighting package on an ML costs $900 when factory installed.
Old 11-17-2006, 08:14 AM   #10 (permalink)
we all know at the time of build it is a 900 dollar option. He was asking about afterwards as an OEM upgrade what would it cost in parts and labor should the dealership to the install
SLK230 HID Xenon Conversion kit vietpersuasion R170 SLK Class 17 05-25-2005 06:23 PM
HID Conversion Kit alee4 W124 E,CE,D,TD Class 5 09-04-2002 03:25 PM
what HID conversion kit you guys install? 99SLK R170 SLK Class 13 08-19-2002 12:16 AM
Phillips HID Conversion Kit Guest (MBNZ) W203 C-Class 1 11-21-2000 02:37 PM
Phillips HID Conversion Kit Guest (MBNZ) W202 C-Class 0 11-14-2000 03:33 PM
