» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 03-02-2006, 09:21 PM   #1 (permalink)
bmustaf
bmustaf's Avatar
Vehicle: ML350 & 300CE
iPod Volume (too low!)
Hi!
After a bit of a warm spell here during the winter (not that our winters are ever too cold in the Front Range), I have been driving my ML with the windows down and the sunroof open.
I have noticed that my stereo's volume is woefully inadequate even at the highest setting when playing from the iPod (using the iPod integration kit, of course).
This is not the case when playing from radio or CD, so I do not believe it to be a deficiency in the stock audio system (I did not spring for the HK system much to my chagrin).
Why is this? Can I fix this somehow? Is there a setting to modify the volume from the "Aux Line In" (iPod Integration Kit). I am using the iPod kit, not the regular 3.5mm minijack AUX input (the iPod kit takes the place of that, though, so it is still called AUX).
Do I need to install an amp so I can get the volume I need? I find this very curious given that the output is fine when the volume is even cranked halfway with the CD/Radio, even with the windows all the way down, hell, it will blow out my ear drums at 3/4...but cranked with the iPod it is barely jammable...
HELP ME!
PS--I have tried Sound Check on and off on my iPod with little to no avail...I imagine I could remaster all my music at a higher intrinsic volume level, although that sounds ludicrous given that most of my music is actually ITMS legal music that has been mastered at the same level as the CD version. I have a feeling this has to do with the MB iPod kit not giving the same amount of input levels as the CD/Radio...
bmustaf is offline   Reply With Quote
Old 03-03-2006, 08:29 AM   #2 (permalink)
mikenj6
mikenj6's Avatar
Date registered: Aug 2005
Vehicle: 06 ML350
RE: iPod Volume (too low!)
Not sure what the issue may be, I haven't had that issue at all. I was going to suggest looking at the sound check but you did that. Do you have the iPod set to the MB suggested setting? I think the only other setting would be the equalizer. My only other suggestion would be to try another iPod to see if that is the issue.
Packages: Appearance (Pewter/Charcoal), Lighting, Entertainment, Comfort and Sunroof:
Options: Hitch, Heated Seats, Rear Airbags, Parktronic, Power Liftgate, Frt & Rr Stainless Steel Skid Plates, DVD Nav Sys, IPod Kit and Craddled Phone Kit
Mods: Hoen Titanium H-7 High Beams, All Weather H-11 Fogs, 5000k W5W Standing Lamps, Chrome Door Lock Pins & Hood Fins, Brabus Monoblock IV 20" Wheels with Hankook Ventus ST RH06 275/45 Tires, Brabus Suspension Kit and Stainless Steel Side Bars
mikenj6 is offline   Reply With Quote
Old 03-03-2006, 07:53 PM   #3 (permalink)
AndyFracica
Where's my auto-leveling?
AndyFracica's Avatar
Date registered: Sep 2003
Vehicle: '06 ML350 '03 E320
bmustaf - 3/2/2006 11:21 PM
Okay I have noticed similar issues with mine but I have the HK system. What I find is that I must turn the volume up with the iPod in the connector (iPod kit connector). I can still get it loud enough to be uncomfortable but when I switch from iPod to radio the difference is volume is quite startling. The radio is much louder than the iPod. I have even tried turning the volume all-the-way up before connecting the iPod but it doesn't make any difference.
Andy
2006 ML350
723 - Pewter, 104 - Macadamia Interior, H04 - Brown Birds Eye Maple Wood, 167 Standard Non-Sport Pkg, 317 Comfort Pkg, 318 - Trim Package, 319 - Lighting Package, 320 - Entertainment Pkg, 324 - Sunroof Pkg, 580 - Std. Climate Control, 873 - Heated Front Seats, 890 - Power Liftgate, Navigation System, iPod interface kit
Modifications:
Added: Chrome Door handle cups, MB Twin Spoke 5-Spoke 18" wheels and tires
AndyFracica is offline   Reply With Quote
Old 03-04-2006, 10:05 AM   #4 (permalink)
firstmb
firstmb's Avatar
Date registered: Jan 2005
Vehicle: 2006 ML350
Never noticed any problems with IPod volume. I do have HK System. check the sound settings on IPod, MB recommends to set it to Pop..
Thanks, D.
________________________________________________
2006 ML 350 - Black, Appearance Package, Navigation System, Entertainment Package, Sunroof Package, Heated Seats, IPod Integration
firstmb is offline   Reply With Quote
Old 03-04-2006, 11:15 AM   #5 (permalink)
Benz4Dirt&Sky
Benz4Dirt&Sky's Avatar
Date registered: Sep 2002
Vehicle: ML430/ SL500 SA
I don't own a 164, but I knows iPods.
Bottom line...
The signal going into your stereo's amplifier from the iPod is pretty weak. We are talking about a device that is designed to run on a battery for 10 hours and drive earbuds.
If that is not acceptable, consider an amplifier between the iPod and your stereo (and IT'S amplifier).
Headroom.com sells portable amps that have to be experienced to be appreciated. Many would consider this overkill, but it will solve your iPod issues forever.
Just a thought from an owner of 7 Macs and 5 iPods.
"I feel much better ever since I gave up hope."
1999 ML430 * Navigation System * 285/70 R17 All terrain T/As -33 inchers*ORC suspension lift kit* Side Step Rail Rock Sliders * Brush Guard * HELLA lamps * Front Skid Plate* All Weather Mats * All-Terrain Rear Seat Cover * Wet Okole Neoprene Front seat covers* All-Weather Rear Cargo Mat/Divider * Yakima LoadWarrior Rack * Roofmount Fullsize spare * Trailer Hitch * Rhino Hitch Step* Rhino Tail Light Guards* WARN 8000i Multi-Mount Winch* Go-Light Remote Motorized Spotlight * Moto-Jack Motorcycle Carrier
2002 SL500 Sliver Arrow w/limited edition James Bond briefcase
Benz4Dirt&Sky is offline   Reply With Quote
Old 03-04-2006, 06:20 PM   #6 (permalink)
AndyFracica
Benz4Dirt&Sky - 3/4/2006 1:15 PM
Bottom line...
The 164 has an iPod connector in the glove box that fits into the the small computer connection on the base of the iPod. The ML interface kit takes care of all of the necessary amplification and power to the iPod.
Old 03-05-2006, 01:51 AM   #7 (permalink)
Benz4Dirt&Sky
"The ML interface kit takes care of all of the necessary amplification and power to the iPod."
I guess the people experiencing "less than the necessary" amplification are just idiots who haven't read the marketing material, then.
The ML interface kit takes care of it.
There is your answer.
Old 03-06-2006, 02:30 AM   #8 (permalink)
dimitriss
dimitriss's Avatar
Date registered: Jun 2005
Vehicle: '06 ML350
The iPod integration kit uses the Line Out feature of the iPod, which produces a stronger signal than the regular earphone one (from the top).
If you're getting lower volume, you should have the kit rechecked by MB.
The amplifier that others mention works wonders, but you will lose the capability to control the iPod through the steering wheel controls, since the amplifier connects to the headphone jack and you'll have to use the regular AUX input, also losing the ability to recharge your iPod while connected.
dimitriss is offline   Reply With Quote
Old 03-28-2006, 09:49 PM   #9 (permalink)
bkushner
Date registered: Mar 2006
Vehicle: 03 SL500/06 ML350
I am having the same problem and just posted about it before reading this message. Any solutions?
Brian
bkushner is offline   Reply With Quote
Old 03-29-2006, 05:04 AM   #10 (permalink)
bkushner
Benz4Dirt&Sky - 3/4/2006 2:15 PM
I am having the same volume problem yet when I hook the very same IPOD to my monster adapter that feeds through the FM radio I have plenty of volume.
Called MB this morning, two separate dealers, neither service department has heard of this problem.
Brian
