If you are using the iPod integration kit, you should have the kit checked by your dealer. The amplifier is built in and the iPod is using its line out instead of the headphone jack.
I have been using my iPod in my ML and I haven't had any problems. I'm using the older iPod ( iPod with dock connector ). I did update my iPod
( http://www.apple.com/ipod/download/ ) to make sure all the software is updated.
As for me, I dont have the MB Ipod kit but use the tape adaptor with my Bose system. I also at the same time, keep the volume on the ipod at 3 quarters high. It can go quite loud.
Would this headphone amplifier help in any way since im using it in the car through the headphone jack of the ipod?
-=- MARKO -=-
*2001 C240*
*1999 C230 Kompressor*
*1983 380 SEL S-Class*
*1985 380 SE (parts)*
I have been so fed up with it now that the weather has become warmer and I'm driving with the windows down and the sunroof open that I'm either going to ask for a refund or have MB fix it.
My SA said this is an acknowledged issue, his voicemail got cut short but he said they can't fix it, but....and then he cut out, so I will call him back tommorow and see what he has to say.
I would have them replace yours, if you are using an approved iPod it should work. I have a dealer installed iPod integration kit with a video iPod and have no volume issues at all.
Packages: Appearance (Pewter/Charcoal), Lighting, Entertainment, Comfort and Sunroof:
Options: Hitch, Heated Seats, Rear Airbags, Parktronic, Power Liftgate, Frt & Rr Stainless Steel Skid Plates, DVD Nav Sys, IPod Kit and Craddled Phone Kit
Mods: Hoen Titanium H-7 High Beams, All Weather H-11 Fogs, 5000k W5W Standing Lamps, Chrome Door Lock Pins & Hood Fins, Brabus Monoblock IV 20" Wheels with Hankook Ventus ST RH06 275/45 Tires, Brabus Custom Suspension 164-016-00 and SS Side Bars
Its not an ipod problem its the mercedes benz kit problem. I installed my own ipod kit in my W163 using my own aux in i have my ipod connected using the dock connector and it will go very loud. The ipod kit i have used is on my parents E350 same ipod that is crazy loud in my ML is almost dead quiet in the E350 that has HK logic 7 system. I recommend in itunes not to boost the output it will make your songs sound like crap. I am thinking that it is more of a software issue with the mercedes system and i hope they fix it soon.
So my SA said it is an acknowledged issue with the AUX port, since the iPod kit hooks into the AUX port, it is limited by the performance of said port.
He didn't have much more information for me other than there is no solution and none is planned. I'm going to take this up with MBUSA, get the dealer out of the picture here. I'm pretty upset that the system is so impotent!
Ok, spent a ton of time on line researching. Take a look at these two programs:
MP3gain
euPOD
There is definitely an issue with the volume on my car kit. Benz OEM integration kit for the SLK55AMG.
but. if you run mp3gain and normalize to 89db, then gun eupod and bump up the volume level 15 to 20% using eupod, the volume becomes more than acceptable, without clipping.
Let me know if this works for you too. Just google both program names and you should find links for the downloads pretty easy.
