» Site Navigation
» Other Sites
Old 11-18-2003, 11:16 PM   #1 (permalink)
pjturner
Date registered: Feb 2003
What is the ML K&N filter part # from K&N
I'm sick of seeing the K&N on ebay $$ - sureley I must be able to go to my local K&N dealer and give them the part number and get the approriate filter.
Is the filter special or simular to the ford explorer etc. filter?
Does anyone know the part number for the ML K&N filter?
pjturner is offline   Reply With Quote
Old 11-19-2003, 01:34 AM   #2 (permalink)
lon000007
lon000007's Avatar
Date registered: Oct 2003
Vehicle: 1999 ML 430
filter!
i am using a K&N Filtercharger air filter at my 99' ML430 parts #33-2703 but i am not sure are this will fit your 350?
cause K&N still not have filter available for 03' model
you may check at: http://www.knfilterchargers.com/search/appsearch.aspx
hope this help![:D]
***Full custom trunk***
·Sony CDX-C90 CD Player
·Sony CDX-757 MX MP3 changer
·Precision Power PPI PCX-480 4 Channel Amplifier
·Precision Power PPI PCX-280 2-Channel Amplifier
·Rockford Fosgate CPCM10 1 farad Power Capacitor
·MB QUART QM 218.61Q 2-Way Components Crossovers
·MB QUART Midrange PWE 130
·2 NAKAMICHI 10" SUBWOOFER
***K&N Filtercharger air filter***
***Bosch Platinum+4 spark plugs***
***HELLA FF50 Driving Lamp***
lon000007 is offline   Reply With Quote
Old 11-19-2003, 06:48 AM   #3 (permalink)
Ratso
Ratso's Avatar
Date registered: Oct 2002
Vehicle: 2004 Honda Pilot
Most parts stores will
have the part number in their system. However, the filter may (and did to me) pass too much oil through tot he Mass Air Sensor and ruin it. That's a $300 part alone. Proceed with caution, or try www.greenfilters.com. A little more cash, but no oil impregnation and higher air flow.
Scott (RRRRRRRRATSOOO)
Sold the Honda Pilot for a F-1250 SuperCrew
but still Got My Eye on Benzworld.org.
Ratso is offline   Reply With Quote
Old 11-19-2003, 08:30 AM   #4 (permalink)
pjturner
Thanks Scott saved my bacon there, don't want any more "in shop" time than necessary - Esp...
Thanks Scott saved my bacon there, don't want any more "in shop" time than necessary - Especially caused by my fault for messing up the MAS.
Looking at the Green USA site now!
Old 11-19-2003, 08:35 AM   #5 (permalink)
Ratso
Ratso's Avatar
well I hate to admit it
but the forum "told me so" before I installed one. I removed it soon after the check engine light came on, replaced it with a fram (for now) and took it to the dealer. Starmark covered the sensor replacement, so I didn't get hurt. But others may if the Sa suggests a surface test on the coils of the MAF sensor prior to approving the warranty repair.
Old 11-19-2003, 09:14 AM   #6 (permalink)
jdanish
jdanish's Avatar
Date registered: Sep 2003
Vehicle: ML500, 2005
K&N
Have been using the #33-2703 for 3000+ miles,in two different ML430's, no problem. If you use one, FACTORY OIL ONLY, dont add any extra, use K&N cleaner, let it dry, then oil, let it DRY, per directions. will not pass oil to the MAF.
jdanish
jdanish- 2005 ML500
Independent Repair Shop Owner
ASE Master Technician, FAA Certified Flight Instructor
jdanish is offline   Reply With Quote
Old 11-19-2003, 10:11 AM   #7 (permalink)
Ratso
Ratso's Avatar
try to tell that to
your SA or MBUSA if the MAF goes bad and they catch you with a K&N. BUT, I am running a V6 vs a V8, which may suck air harder they way some of us drive.
Old 11-19-2003, 10:17 AM   #8 (permalink)
pjturner
Okay from what I can understand - You are saying that the stock filter as is comes is oile...
Okay from what I can understand - You are saying that the stock filter as is comes is oiled (factory) and used as is will not mess up the MAS.
Then when I do clean it and re-oil it oil as directed.
Sounds like a bit of a gamble... however in your experience is the increase in HP worth it?
Old 11-19-2003, 10:41 AM   #9 (permalink)
Drew
BenzWorld Senior Forum Host & Managing Editor
Drew's Avatar
Date registered: Jul 2002
Vehicle: '00 ML320 Elegance
No...
The factory filter is not oiled. When it gets to a certain mileage, you simply replace it with a new one. The re-oiling of the K&N is what causes the MAF sensor to malfunction, as the oil can damage the sensor.
There is barely any perceptible increase in power. Not only that but the K&N lets in larger dirt particles.
BenzWorld.org Senior Forum Host & Lighting guru
MB OEM Bi-Xenons with E-code modification, custom-cut StonGard Light protection film, Hella FF100 & FF200 foglamps with wireless switch, Hella dual tone air horns, Bosch ParkPilot reverse warning system, Tomar Hide-a-way emergency vehicle front strobes, integrated reverse warning strobe lights with wireless switch, chrome handle accent strips and chrome door handle shells, AMG chrome ringed gauges, Euro M-class footwell net, 3M reverse safety fresnel lens, Euro blindspot interior mirrors, MCS GPS nav system, chrome headlamp rings, chrome fender signal rings, Personalised designo interior, Drinkholders.com burl walnut ML cupholder, hardwired Valentine One radar detector, LED-based front and rear LED footwell ambience lighting, illuminated MB door sills for each door, Clear acrylic hood deflector, Weathertech window deflectors, EGR rear deflector, 3M Scotchtint 50% tint on front windows, 3M Scotchtint 20% tint on top 4" of windshield, driver side mounted fire extinguisher, chrome tailgate handle, "Elegance" side badges, '02 Bose tweeters and sail panels, '02+ tailgate filler panel, AMG silver painted/chrome accented front grill, silver painted lower bumper grill, MB OEM Style 1 chrome sidesteps & chrome brushguard with skidplate, MB OEM front mudflaps & aftermarket flexible rear mudflaps, chrome door rubstrips, MB Lamella Skyview roof deflector, MB accessory roof crossbars & ski rack, AMG oval exhaust tip, 17" EVO II Sport package wheels & Michelin Cross Terrains, DesignTech halogen backup bulbs, Formymercedes.com 20" LED brake strip with Flash alert, 6" 3rd brake lamp LED strip, High-intensity LED taillamps, front and rear LED amber turn signals, HyperWhite LED city lamps
Drew is offline   Reply With Quote
Old 11-19-2003, 10:52 AM   #10 (permalink)
tcp_ML500
tcp_ML500's Avatar
Amazing how people think such a small thing can increase HP noticeably
Don't ask for people's opinion, ask for dyno data.
Asking for opinions will get you a bunch of unreliable funky answers on which to base a decision that can adversely affect your engine
Asking for numbers will prove you that you would have a better use for your cash (say, rocky road ice cream)
Seal Clubbing Champion '95 '97 '98 '01
Proud member of PETA, People for the Edible Treatment of Animals
Amateur Gynecologist & Cunning Linguist
tcp_ML500 is offline   Reply With Quote
