» Site Navigation
» Other Sites
Old 05-29-2003, 04:20 PM   #1 (permalink)
Date registered: Sep 2002
BAS/ESP and ETS Lights On/Off: Is it safe to drive?
1999 ML320 with 53k+ miles. Lights come on and off after I re-start the car. My appointment (with Stead Motor@Walnut Creak, CA) is next Monday morning. Thanks.
1999 (pre-owned) ML320 Black/Tan
tjhsiao is offline   Reply With Quote
Old 05-29-2003, 05:29 PM   #2 (permalink)
tcp_ML500's Avatar
A few questions
Do the lights stay on?
How long?
Do they come on when you re-start but not start?
Do they come on when you stop without turning the engine off (say a stop sign for example)
If they are constantly on from the time you start the engine and do not turn off, you owner's manual should tell you that it is quite unsafe to drive the car.
If they come on intermittently and for a short period of time, after braking to a stop and taking off, but not at all times, you might have the same problem I've had fixed last week, a stop brake switch gone bad. If your dealer rus a short test, that would be a C1200 error code.
Again, if the lights are on, your owner's manual warns you not to drive, check it out an ask your service advisor.
Seal Clubbing Champion '95 '97 '98 '01
Proud member of PETA, People for the Edible Treatment of Animals
Amateur Gynecologist & Cunning Linguist
tcp_ML500 is offline   Reply With Quote
Old 06-04-2003, 05:03 PM   #3 (permalink)
Problem was Stop Lamp Switch....
Part# 001-545-20-09
Cost is $16.61 and 1.3 hours of labor ($162).
Forgot to call the Claim Advisor (1SourceWarranty.com) before repair was done. Needed to pay this one myself[xx(]
Old 06-04-2003, 05:12 PM   #4 (permalink)
BenzWorld Post Whore
S4toML's Avatar
Date registered: Dec 2002
Vehicle: 05 C320 4MATIC
Hmmmmnnn...
I've recently experienced this "BAS/ESP" light coming on. Mine remained ON for as long as the engine is running.
How long?
IT remained lit for as long as the engine is running.
My "BAS/ESP" light went off AFTER I restarted the engine and it remained OFF until the following day (the second occurence).
NOPE! Not on mine, the BAS/ESP light went on after starting the engine.
If they come on intermittently and for a short period of time, after braking to a stop and taking off, but not at all times, you might have the same problem I've had fixed last week, a stop brake switch gone bad. If your dealer rus a short test, that would be a <b>C1200 error code</b>.
YEP! Sounds exactly my "BAS/ESP" symptoms. Perhaps it is the same C1200 DTC. Any details on what triggers <i>C1200</i>?
My Service A is coming up really soon so I'll put this down on my list of things to be checked at while at service.
2005 C320 4MATIC
2003 ML350 Inspiration Edition -- traded-in 11/2007
S4toML is offline   Reply With Quote
Old 06-04-2003, 06:14 PM   #5 (permalink)
UncAl's Avatar
Vehicle: '08 Acura MDX
Re: Hmmmmnnn...
C1200 is "Stop Light Switch Open/Shorted/Implausible"
_______________
'08 Acura MDX w/ Tech package
Previously - '98 ML320 - 285k miles in 7 years
UncAl is offline   Reply With Quote
Old 06-04-2003, 07:52 PM   #6 (permalink)
tcp_ML500's Avatar
Get it checked, changed the switch (you're definitely under warranty) all is well now!
Old 06-04-2003, 07:53 PM   #7 (permalink)
tcp_ML500's Avatar
Glad it was fixed, that switch sure is faulty on a few of our MLs
Old 06-05-2003, 06:34 AM   #8 (permalink)
AC_ML's Avatar
Vehicle: Black 2005 ML 500
Anybody knows how difficult is to change the stop lamp switch on the ML? On the hondas it
Anybody knows how difficult is to change the stop lamp switch on the ML? On the hondas it takes 5 minutes to do it. It is just a bolt sensor with a nut in the upper part of the brake pedal and a connector..
It will really be nice to know if it is that straight forward..
AC
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Falken Ziex ST/Z + Bi-Xenons(+ Drew's e-code mod), Yakima roof bars. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history.
AC_ML is offline   Reply With Quote
