OT: Subs and Amp for sale
633 views 2 replies 2 participants last post by  darkscythe
I am selling Two 13 Inch JL Audio W7 Subwoofers. These MSRP at above $750 each. And a Concept 2400 watt amp, MSRPs at about $1000. See bwlow for details.
These have been used for less than a year, and still have a warranty, they were in a Toyota Seqouia, and professionally installed. These are not mine, but a friends. He is asking 1600, w/o s&h. If you are interested and would like a lower price, I will try to lower for you. At a deal like this, you can not pass up, even with a warranty still on it, so buy, blow them, then return to JL and get new ones if it will make you feel safer. The reason I didn't buy is becuase I don't have the money, and I'd hate to see a deal like this go to waste.
Concept CCD-2400
http://mainstreet-audio.com/Merchant2/merchant.mv?store_code=1&screen=PROD&product_code=CCD2400A
Subwoofer Amplifier
- 2400 watt class "D" mono-bloc amplifier
- 4 ohm 600x1
- 2 ohm 1150 x 1
- 1 ohm 2400 x 1
- Variable crossover with remote sub level control
- Frequency response: 50hz - 350hz
JL Audio W7
http://www.infinitecaraudio.com/cgi-bin/icastore.cgi?user_action=detail&catalogno=13W7
Description:
Dimensions:
Frame Diameter: 14 in. (356 mm)
Mounting Hole Diameter: 11.9 in. (302 mm)
Mounting Depth: 10.5 in. (267 mm)
Overall Depth: 12 in. (305 mm)
Magnet Diameter: 8.38 in. (213 mm)
Pole Vent Clearance: 0.75 in. (19 mm)
Displacement: 0.21 cu. ft. (4.5 ltrs)
Enclosure Recommendations:
Sealed Range: 1.5 - 2.25 cu. ft. (42.48 - 63.72 ltrs)
Recommended Sealed Volume: 1.875 cu. ft. (53.1 ltrs)
Fc: 40.8 Hz
F3: 36.3 Hz
Qtc: 0.806
Ported Range: 2.0 - 2.75 cu. ft. (56.6 - 77.9 ltrs.)
Recommended Ported Volume: 2.375 cu. ft. (67.3 ltrs)
Recommended Tuning: 30 Hz
in a box or no, the box alone will be insane $$$ becuase it has to be built to the W7 st...
in a box or no, the box alone will be insane $$$ becuase it has to be built to the W7 standards :)
#3 ·
Re: in a box or no, the box alone will be insane $$$ becuase it has to be built to the W7 st
Nah man, no box, but it's gotta be custom, just called him to tell him your question. He will lower price to $1300, but buyer pays shipping, keep in mind I make no money whatsoever, just helping you guys as much as you helped me. so $1300 is the price, with warranty on them.
