Will there be any problem or side effect after install a after market Xenon kits on a 03 ML? Will it give a check headlight warning like BMWs?
i updated my ML headlights to 02+ halogens.. and i also got a 7500HID aftermarket kit installed... i got that done for more than a week.. havent seen any problems, no check engine light or wat so ever.. however, my Ml is a 98 one... so it might be different. hope this helps..Will there be any problem or side effect after install a after market Xenon kits on a 03 ML? Will it give a check headlight warning like BMWs?
Unless you get the obsure computer setting changed, the lights will flicker. Additionally, aftermarket Xenons aren't the most ideal (or legal). If you really do want to go to Xenons, the MB OEM Bi-Xenons are the way to go.Will there be any problem or side effect after install a after market Xenon kits on a 03 ML? Will it give a check headlight warning like BMWs?
Pre-'02s do not have any problems, but '02+ definitely will. BTW Kevin, I hope that you changed your headlamp fuses to ones with higher amperage.i updated my ML headlights to 02+ halogens.. and i also got a 7500HID aftermarket kit installed... i got that done for more than a week.. havent seen any problems, no check engine light or wat so ever.. however, my Ml is a 98 one... so it might be different. hope this helps..
Check with Steve at s_krabbenborg@hotmail.comany Idea on where Can I get a hold of the OEM Bi-Xenon headlight kit?
hey Drew, thanks for da tip! wat amperage should i change it to?Pre-'02s do not have any problems, but '02+ definitely will. BTW Kevin, I hope that you changed your headlamp fuses to ones with higher amperage.i updated my ML headlights to 02+ halogens.. and i also got a 7500HID aftermarket kit installed... i got that done for more than a week.. havent seen any problems, no check engine light or wat so ever.. however, my Ml is a 98 one... so it might be different. hope this helps..
They are 7.5 amp fuses? If I recall correctly, you will have to bump them up to 15 or 20 amps (20 sounds more accurate than 15). There should be a fuse for each lamp, so you will need two of them; buy a pack for spare usage. They're extremely inexpensive anyway.hey Drew, thanks for da tip! wat amperage should i change it to?
sorry drew, i am so not good with electronics.. so can u tell me where the fuses are located? i know there are two fuses for my aftermarket HID kit, do i need to change those too?They are 7.5 amp fuses? If I recall correctly, you will have to bump them up to 15 or 20 amps (20 sounds more accurate than 15). There should be a fuse for each lamp, so you will need two of them; buy a pack for spare usage. They're extremely inexpensive anyway.hey Drew, thanks for da tip! wat amperage should i change it to?
The Bi-Xenon headlamps have four pins, but the stock harness only has three!Someone put Bi-xenons in their ML, just move the pins.
