Old 01-17-2003, 12:15 AM   #1 (permalink)
Date registered: Nov 2002
Vehicle: ML350, ML320, C320
How many bulbs are in the instrument cluster?
And... how difficult is it to take the cluster apart. The right side from the center of the speedo just died tonight [xx(].
Thanks
04 ML350
01 C320
98 ML320
hawaiibenz is offline   Reply With Quote
Old 01-17-2003, 06:34 AM   #2 (permalink)
BenzWorld Post Whore
S4toML's Avatar
Date registered: Dec 2002
Vehicle: 05 C320 4MATIC
That should be covered under warranty, no?
2005 C320 4MATIC
2003 ML350 Inspiration Edition -- traded-in 11/2007
S4toML is offline   Reply With Quote
Old 01-17-2003, 07:17 AM   #3 (permalink)
Vehicle: 1998 ML320
If I remember correctly, there are nine backlight lamps in the instrument cluster. Three ...
If I remember correctly, there are nine backlight lamps in the instrument cluster. Three lamps provide the backlight for the temperature display, the clock display, and the odometer. The other six lamps provide the backlight for the gauges. Buy nine lamps and replace all of them when you remove the cluster. I replaced only two of them initially then had to repeat the process two months later to replace another lamp. The second time I removed the cluster I just replaced all the backlight lamps I had not replaced the first time. You might also want to purchase new lamps from the local BMW dealer as their instrument clusters use similar lamps but last longer and are half the cost. You need 12V 1.5W lamps. The cluster is relatively easy to remove. There should be some instructions in the archives.
Alex
alex lynch is offline   Reply With Quote
Old 01-17-2003, 09:08 AM   #4 (permalink)
Thanks
Thanks for the info. Too bad my ML has 71k on the clock... no warranty work for me...
Old 01-19-2003, 07:51 AM   #5 (permalink)
eMLi's Avatar
Vehicle: ML320, C240, '72 280SE, '67 280SL
while you are at it add the new instrument casing from the ML55 for a cool look
eMLi is offline   Reply With Quote
