Old 01-03-2003, 08:45 PM   #1 (permalink)
rand's Avatar
Date registered: Sep 2002
Vehicle: ML 500 Sport
"HID-DRL" activated in programing,now for code "E" retro?
I had my dealer set the programming to allow the low beam HID to run when running. The low beams will automaticaly shut off after about 5min if the car is in park then reactivate when shifting to dive. Im wondering if there is an inline adapter[dont like the idea of bypassing by cutting and splicing] to charge the relay continuously to the halogens to allow their use again when on high beam and flash to pass. This is the only draw back from this in that it totaly renders the halogens useless.
Could another set of HIDs be placed where the halogens are? Hummmmmmmmmmm
rand is offline   Reply With Quote
Old 01-03-2003, 10:04 PM   #2 (permalink)
Bora20's Avatar
Vehicle: 2000 E320S4M
Re: "HID-DRL" activated in programing,now for code "E" retro?
Read Drew's publication: http://mbnz.org/publications/pub.asp?id=67
No as you will lose the flash to pass function of these lights. The function will return once you perform the above modification.
Dan - 2000 E320 Wagon 4Matic
Gone - *2002 ML320 Elegance**2001 C240 Sport**1999 E430 Elegance*
Bora20 is offline   Reply With Quote
Old 01-04-2003, 01:59 PM   #3 (permalink)
scorchie's Avatar
Vehicle: CLK55/G500/E55/ML55/etc.
Possible solutions
Well...
The relay activation circuit is wired directly to the low beam wire. It is a normally closed relay, and when activated, opens the switched circuit. The wiring for the halogen high beam is the switched circuit, and so when the relay is energized, it is shut off.
So...
You don't want to energize the relay all the time, you want it to NOT be energized.
You can't do this with an inline adapter.
If you don't like cutting and splicing, but you don't mind cutting, just cut the wire going to the relay, at the connector that goes into the headlight. Cutting it at the connector would solve several issues:
1) No new insulation required. No tape, no tubing, no nothing, because you've not touched an energized wire that is in the light housing
2) Even if you use Drew's "cut & splice" method, your relay still activates when the low beams are on, thus increasing current draw. This relay is possibly why two ground wires are needed with the newer headlights. Dunno, the older headlights had three 55-watt bulbs with only one ground wire. Even if you use the cut & splice method, it might be a good idea to cut the wire to the relay
3) You can return your headlights to factory condition by removing the pin from the connector, and recrimping the relay wire. Thus if you ever sold the headlights later, you wouldn't need to worry about selling a modified part (two concerns with selling a modified part are lower resale value and legal liabilities)
You could always just install a set of Euro-spec bixenons ($800 + shipping) and this would solve your issue as well.
I will have my write-up on modifying US-spec lights in this manner as soon as I get my hands on a pair; it will accompany my write-up on modifying Euro-spec lights.
-s-
1987 190E / 1987 300E x2/ 2001 CLK55 / 2001 ML55 / 2002 G500 / 2003 E55 / 2006 R350 / 2006 G450 / 2007 sumtin sumtin
scorchie is offline   Reply With Quote
Old 01-07-2003, 04:51 PM   #4 (permalink)
rand's Avatar
Sorry !! Missed the posting
This sounds like a better alternative. Could the ground wire be deconnected as well from the relay at the frame or is it not grounded to the frame but through the harness? Looking forward to your new info.
Many thanks
Old 01-07-2003, 06:29 PM   #5 (permalink)
Bora20's Avatar
You could remove all the wires and completely remove the relay if you chose to. ...
