» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 12-25-2002, 01:17 PM   #1 (permalink)
Date registered: Dec 2002
Vehicle: Ml 320
Engine Cleaning
Well from my most recent off roading the entire engine bay has become extremly dirty. I was wondering how can I clean it?
00 ML 320
zubyc is offline   Reply With Quote
Old 12-25-2002, 01:23 PM   #2 (permalink)
garyroseyu's Avatar
Date registered: Sep 2002
Vehicle: 05 E500
Steam clean....
or if you don't want to spend too much money just use Simple Green.
<I><B>2005 E500 "AMG Sport" <FONT COLOR="SILVER">Brilliant Silver</FONT></B></I> <FONT SIZE=-7>
garyroseyu is offline   Reply With Quote
Old 12-25-2002, 01:54 PM   #3 (permalink)
UniquelySanFrancisco's Avatar
Vehicle: 2002 ML500
Gary, could you elaborate more on the steam clean and simple green.
It sounds like a good piece of info to know when cleaning the engine bay.
When you say steam clean, it sounds like you have to buy a steam cleaner? But the only steam cleaners I know are for curtains, clothes and furnitures.
As for Simple Green, isn't that a degreaser? Wouldn't it be dangerous to use a degreaser in or around the engine as it may degrease everything???
I have never cleaned that part (engine bay) of the car before. It would be cool to know how.
Thanks Gary!
UniquelySanFrancisco is offline   Reply With Quote
Old 12-25-2002, 02:20 PM   #4 (permalink)
garyroseyu's Avatar
Vehicle: 05 E500
Re: Gary, could you elaborate more on the steam clean and simple green.
No, those are not powerful enough. What I meant was to take it to the detail shop and have them steam clean it for you. You might be able to find some auto shops with one that you can use for a fraction of the cost and do it yourself.
Ahh, Simple Green is the safest and most effective cleaner out there IMHO. It's non-toxic, bio-degradable, and non-corrosive. You can drink the stuff (don't recommend it though [:D]). Just spray and wipe. Yes, it degreases, but not in a corrosive way. The active ingredient is Surfactant agents that lift grease and oil up off of the surface, wetting agents help Simple Green penetrate soils, and emulsifiers put those soils into solution so that they can be washed away. http://www.simplegreen.com/
If there's lots caked on dirt, I would go and steam clean it. If it's just dusty, I would just apply Simple Green with some elbow grease.
Old 12-25-2002, 03:29 PM   #5 (permalink)
Vehicle: 2002 ML500
Ahh...I get it now. (sorry for the noob question) Thanks for the helpful info!
Old 12-25-2002, 04:26 PM   #6 (permalink)
garyroseyu's Avatar
Vehicle: 05 E500
Your welcome David. I should've clarified in the first place. : )
Old 12-25-2002, 04:36 PM   #7 (permalink)
Member
Drew's Avatar
Date registered: Jul 2002
Vehicle: '00 ML320 Elegance
It's quite simple to clean...
Firstly, make sure that all of the caps to the bottles, etc. are tight. Next, take a plastic bag and cover up the alternator, located on the left hand side of the engine block. Cover it up well.
You can then go ahead and spray some degreaser such as Simple Green. Don't use too much or it there will be to much lather. You can then lightly spray some water and brush down the area lightly. Next, hose it off with a light spray. It's better to do multiple light sprays rather than one heavy spray (hosing down). After that, let it dry and you're done!
Don't be surprised if you hear some squealing from the belts after you first start up the engine. This is completely normal as the belts, if wet, will slip momentarily.
Drew is offline   Reply With Quote
Old 12-25-2002, 06:00 PM   #8 (permalink)
AlBoston's Avatar
Vehicle: 1999 Mercedes ML320
how the hell do u bag the alternator? I never did this and all my cars are fine....
1999 ML320 Mods: ML500 grille, ML55 headlights, MY00 door seals (Delivered 2/18/99)
2003 C320 4matic Mods: coming soon(Delivered 5/7/03)
2002 Lexus IS300 Mods: OEM graphite polished wheels, painted brake rotor hubs and calipers (Delivered 3/1/02)
AlBoston is offline   Reply With Quote
Old 12-25-2002, 06:23 PM   #9 (permalink)
Vehicle: Ml 320
Thanks for the info....I'll probably just get it steam cleaned because it will take a very...
Thanks for the info....I'll probably just get it steam cleaned because it will take a very long time to do it the Simple Green way.
Old 12-25-2002, 06:41 PM   #10 (permalink)
Member
Drew's Avatar
Just cover it with a plastic bag...
so that the water doesn't get into it when you hose down the engine. Why take the chance when you can cover it in 2 seconds? I was told to do this by the service technicians and the shop foreman and it just makes common sense not to wet a major electrical component.
