» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 11-25-2002, 04:53 PM   #11 (permalink)
Airjunky's Avatar
Vehicle: 2002 ML320
Re: Re: Re: Thule cross bars are LOUD!!
I just installed Thule crossbars in preparation for a ski rack and the noise at over 40 mph is loud. Any ideas or suggestions about this situation would be appreciated. I would like to avoid the free advertising of Thule by using their windscreen.
Stewart
Return it, install the cheap $100 draw tite hitch and buy a hitch mount rack.
Junky,
The hitch mounts make the skis VERY dirty from all the debris flying about. If you use a rear hitch, you must wrap/cover the skiis first!!! I will take the noise.
I understand your concerns but you asked for a resolution to your issue and a hitch rack will solve it. I've have roof mount racks and hitch mount racks and use them both depending on application. But the ML being as noisy as it is and as tall as it is really isn't suited for a roof rack. Windscreens may help but often make the situation worse and may take hours or days of tinkering to get the right positioning and angle.
Airjunky is offline   Reply With Quote
Old 11-25-2002, 05:40 PM   #12 (permalink)
Vehicle: 2000 ML320
Ford has the answer...
Stewart
My '89 Taurus didn't make any noise from the roof rack. Agreed though, if MB supplies roof rails they ought to provide quiet cross bars to go with them. Maybe they wanted too but couldn't make them work. Somebody decided that rather than fix the problem lets' leave them off! Problem solved.
warning triangle, 133,000 miles
ccweems is offline   Reply With Quote
Old 11-26-2002, 12:38 AM   #13 (permalink)
UniquelySanFrancisco's Avatar
Vehicle: 2002 ML500
I installed the OEM skyrview deflector and OEM cross bars (basic carrier) = no wind noise
UniquelySanFrancisco is offline   Reply With Quote
Old 11-26-2002, 10:22 AM   #14 (permalink)
Benz4Dirt&Sky's Avatar
Date registered: Sep 2002
Vehicle: ML430/ SL500 SA
Now this has got to take the prize for most ridiculous complaint. IF YOU PUT A RACK ON ...
IF YOU PUT A RACK ON TOP OF YOUR CAR IT WILL MAKE NOISE.
Oval cross bars will surely cut down some of the noise. Guess what. They don't accept the myriad of attachments that you may want.
Life is about trade-offs.
I LOVE the noise my rack makes above 40MPH. It sounds like VICTORY.
"I feel much better ever since I gave up hope."
1999 ML430 * Navigation System * 285/70 R17 All terrain T/As -33 inchers*ORC suspension lift kit* Side Step Rail Rock Sliders * Brush Guard * HELLA lamps * Front Skid Plate* All Weather Mats * All-Terrain Rear Seat Cover * Wet Okole Neoprene Front seat covers* All-Weather Rear Cargo Mat/Divider * Yakima LoadWarrior Rack * Roofmount Fullsize spare * Trailer Hitch * Rhino Hitch Step* Rhino Tail Light Guards* WARN 8000i Multi-Mount Winch* Go-Light Remote Motorized Spotlight * Moto-Jack Motorcycle Carrier
2002 SL500 Sliver Arrow w/limited edition James Bond briefcase
Benz4Dirt&Sky is offline   Reply With Quote
Old 11-26-2002, 12:59 PM   #15 (permalink)
Stewart's Avatar
Vehicle: 2005 ML350
Re: Now this has got to take the prize for most ridiculous complaint.IF YOU PUT A RACK ON
[quote]
Thank you very little for the negative comments. I was merely saying that my previous two Jeep Grand Cherokees with factory racks made NO noise and the much more expensive MB product makes a ton of noise. Go figure??
Remember what your mama said, if you have nothing positive to say, keep it to yourself. These forums are here to help with perceived problems, not to voice your ridiculous opinions.
Stewart
PS Do you really like the noise??????
Stewart is offline   Reply With Quote
Old 11-26-2002, 01:58 PM   #16 (permalink)
Airjunky's Avatar
Vehicle: 2002 ML320
Re: Re: Now this has got to take the prize for most ridiculous complaint.IF YOU PUT A RACK ON
[quote]
Stewart
Do you think you can really fool yourself into thinking that JGC racks generate no noise at all? Could it be that the engine noise and soundproofing in that car was so bad that it obscured your rack noise. If you want no noise, put the stuff inside, put it on the hitch, or don't carry it at all. There is no miracle roof mount rack system that generates no noise. Cars that come with factory crossbars, like the JGC, give the illusion of lower noise because you've never experienced the car without the crossbars on. There is a reason why MB chose to not install the cross bars.
Last piece of advice - wrap your entire head in some flexible foam insulation when you drive. This should cut out 100% of all noise, once you get past the initial impact of the crash and your car stops moving.
Old 11-26-2002, 02:34 PM   #17 (permalink)
tsanjose's Avatar
Vehicle: 2000 ML430
Send a message via ICQ to tsanjose Send a message via AIM to tsanjose Send a message via Yahoo to tsanjose
Stewart...
firstly your initial complaint was about the thule cross bars, not the oem mb ones. i dont think you should be comparing your jeep with your ml cause you're not making sense. secondly, my original suggestion was to get a fairing. it's a must when adding cross bars...
now can you see why there's so much hostility towards you?
tsanjose is offline   Reply With Quote
Old 11-26-2002, 02:37 PM   #18 (permalink)
Stewart's Avatar
Vehicle: 2005 ML350
Another ass heard from
If anyone has any intelligent comments to make, PLEASE jump in at any time. Jeez guys, I only asked a question!!!!!!
Old 11-26-2002, 02:40 PM   #19 (permalink)
tsanjose's Avatar
Vehicle: 2000 ML430
seriously tho...
get a fairing, make sure it spans most of the way across the front bars only. trust me, it'll stop most if not all of the noise...
Old 11-26-2002, 02:52 PM   #20 (permalink)
Stewart's Avatar
Vehicle: 2005 ML350
Thanks!!
I will probably just get the fairing and make my life simple. I am not stirring trouble, just making a point that I expected more from MB.
[:D]
