Low Range Light Flashing - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 10-11-2001, 12:19 PM
Joe
Guest
Posts: n/a
Quoted: Post(s)
Occasionally when I start my ML (98)The low range light blinks 7-10 times then stops. Does this sound strange? I have never even used the low range gear setting. Could it be some sort of error in the computer? Has anyone else had this occur?<br>
Thanks<br>
Joe
post #2 of 22 (permalink) Old 10-12-2001, 06:18 AM
PaulZ
Guest
Posts: n/a
Quoted: Post(s)
Mine does it too. I figured it is normal?
post #3 of 22 (permalink) Old 10-12-2001, 11:20 AM
Steve (Austria)
Guest
Posts: n/a
Quoted: Post(s)
Re: Low Range Light Flashing
This is definately not normal, and you should have it checked. You would know if it switched into low, but still it should not happen.
post #4 of 22 (permalink) Old 10-16-2001, 07:56 AM
ken
Guest
Posts: n/a
Quoted: Post(s)
sounds like someone pushed the low range button :-)
Fairly common thing to do. Press it when it's not in neutral and symptoms are as you describe.<br> Press it once to disengage it.<br> <p>
post #5 of 22 (permalink) Old 10-25-2006, 08:33 AM
Vehicle: 2000 ML430
Thanks<br>
Joe
My 2000 ML430 does the same thing... I have not touched the button to cause this. I tested LOW RANGE for the first time this morning and It did not function... I think.
I checked the manual before attempting. I was parked and in neutral, under 1500rpm. The LOW RANGE light flashed as it should put never came on solid afterward.
jdeitch is offline
post #6 of 22 (permalink) Old 10-25-2006, 09:09 AM
Date registered: Aug 2006
Vehicle: ML 500 '02
Quoted: 29 Post(s)
If it flashes two times and stays on, then the system is engaged, but I guess you already knew that. Look here for more info:
http://www.mercedestechstore.com/pdf...2003-02-04.pdf
Good Luck
DL
designo? is offline
post #7 of 22 (permalink) Old 10-25-2006, 09:55 AM
Kajtek1's Avatar
Quoted: 1166 Post(s)
Let me guess?
Another sensor malfunction?
Even my youngest knows by now, that sensors are the problem 90% of the time.
Kajtek1 is offline
post #8 of 22 (permalink) Old 10-25-2006, 10:23 AM
Vehicle: ML 500 '02
Quoted: 29 Post(s)
True, but it could be the motor that changes the lo/hi I suppose.
DL
designo? is offline
post #9 of 22 (permalink) Old 10-25-2006, 03:05 PM
Vehicle: 2001 ML 320
Wink
Originally Posted by Kajtek1
Let me guess?
yeap it sounds like that.
the low range should be on after flashing for 3 sec..
every collision changes the speed and direction of both molecules involved
EddieBenz is offline
post #10 of 22 (permalink) Old 10-25-2006, 03:29 PM
asianml's Avatar
Date registered: Sep 2005
I need to try engaging low-range sometime. I'm just afraid since it's been years since it was engaged, that I'll year some sort of weird mechanical thing, and a thing a loud crack.
I hope my parents somehow take me to a street thats really steep and requires low-range, then I can test it out. Don't feel like doing it in the driveway....Just takes the fun out of doing it.
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
