Hi there!
This is my first posting. I tried reading other posts for same issue especially the one ML430 won't start/crank/turn over, but it was a bit confusing!
I have a 2003 ML500 that also will not start/crank over/turn on. This began after a dead battery replacement. The dash lights SRS/Airbag off only come on for about 4 sec then turn off in position 2; no other lights in the instrument panel cluster come on. Engine will not turn over.
New battery voltage has been checked and cranking power has been checked - no issues.
Radio, power seats, power windows, wipers, lights work (although I do have a burnt out low beam) . All fuses checked - all ok. No start error. No codes pulling. Tried resetting the FSS as it shows -8 days with two wrenches - will not work, keep getting a 45 1 after reset.
Key Fob has no LED light. Only have the 1 key.
I'm at a loss as to why ML500 won't start.
