Oversteer on Freeway bends - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 06-19-2017, 03:29 AM Thread Starter
Neo7's Avatar
Date registered: Mar 2015
Vehicle: 2002 ML270CDI
Quoted: 27 Post(s)
I've always felt that the steering on my ML270CDI is too light. But recently fix the HP Pump and have noticed a lot more power from the engine. I'm told by a friend of mine (who owned an ML320) that my ML has firmer suspension than most. But today I was on the Freeway, doing 65mph up a long hill. When I powered up the hill and steered into the left hand bend the steering went super light and the car seemed to over steer (which scared the cr*p out out of me!).
Any ideas whats going wrong?
Many thanks.
Neo
Neo7 is offline
post #2 of 14 (permalink) Old 06-19-2017, 05:41 AM
ArcticDweller's Avatar
Date registered: Jun 2008
Vehicle: '95 SL500, '99 ML320, '08 ML550 4MATIC w/Sport & Lighting Pkg, '12 ML350 4MATIC w/P2 Pkg & Pano Roof
Quoted: 95 Post(s)
Many thanks.
Neo
Hi Neo,
With 15 years on your ML270, I would check out your PSR (Power Steering Rack).
With age, the internal valves in the PSR wear out, and the result is a lot of "slack" in the steering.
At times, the steering will feel super "light" and the steering will shift either left , or right, on its own..... very unnerving.
This may be what you are currently experiencing.
God Bless, Arctic
ArcticDweller is offline
post #3 of 14 (permalink) Old 06-20-2017, 12:06 AM Thread Starter
Neo7's Avatar
Quoted: 27 Post(s)
Thanks Arctic
I haven't noticed any slack manoeuvring at low speeds and the steering feels just a light at low or high speeds but how do I go about testing the PSR?
Neo7 is offline
post #4 of 14 (permalink) Old 06-20-2017, 01:28 PM
Quoted: 95 Post(s)
Thanks Arctic
Hi Neo,
First thing to do is make sure the Front End is okay..... Tie Rods, Ball Joints, Wheel Bearings, etc.,..... no play anywhere.
To check the PSR, this article is a good place to start:
Diagnose Rack & Pinion Steering
Hope this is of help.
God Bless, Arctic
post #5 of 14 (permalink) Old 06-20-2017, 04:50 PM Thread Starter
Neo7's Avatar
Quoted: 27 Post(s)
Thanks Arctic ;-)
Neo7 is offline
post #6 of 14 (permalink) Old Yesterday, 12:58 AM Thread Starter
Neo7's Avatar
Quoted: 27 Post(s)
Ok, After inspecting what I thought was all the suspension and steering bushes today I was at loss what the problem could be. The PO had told me that I could always ask Mercedes to do a "Complementary Condition Assessment Inspection" so I called them and they now charge $250 for that. But I got chatting to the guy on the phone, got half way through my description and he interrupted me with "The Steering Rack Bushes are worn". So checked them out, with the wife rocking the wheel, and he was bang on!!!
So now my big question is .... Is it possible to change the bushed without unbolting the tie rods ends and hoses? In other words can I unbolt the 2 mounting bolts (and possibly steering shaft coupling) shift the rack out a bit and swap-out the bushes? .... Someone please give me some good news lol!
All the best.
Neo
Neo7 is offline
post #7 of 14 (permalink) Old Yesterday, 03:22 AM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 , 2008 C200k Elegance 2006 C180k sports(sold)
Quoted: 496 Post(s)
Would be easier to just disconnect it at the outer ball joints and steering knuckle spline. Make sure you mark exactly where that comes off. Also check where the spacers are aswell. Put them back they way they come out.
I had to replace my steering rack with similar systems to what you have. Try it first with the bushes and see what happens.
mattml430 is online now
post #8 of 14 (permalink) Old Yesterday, 02:21 PM
art_arev's Avatar
Date registered: May 2013
Vehicle: ML 500 2002 RHD, ML55 AMG 2003 RHD
Quoted: 585 Post(s)
Send a message via Skype™ to art_arev
the rack has to come out to change the bushes. It is not possible to do it while the rack is still on the car but slightly pushed forward. So, remove inner + outer tie rods, then the rack & have the alignment done afterwards.
Was the rack & the bush moving or the rack is moving while the bush is not mobile?
I would tighten the bracket bolts first before removing the rack. They might be loose.
Art
art_arev is online now
post #9 of 14 (permalink) Old Yesterday, 02:43 PM Thread Starter
Neo7's Avatar
Quoted: 27 Post(s)
Thanks Matt.
I'm thinking that with the steering knuckle disconnected and the front wheels off the ground (allowed to turning outwards in opposite directions) then there should be "Slack-around-the-Rack" lol! ....and I might be able to move it forward enough and to knock the bushes out.
But the things I don't know is ...
  • Once the mounting bolts and steering knuckle are disconnected how hard will it be move the rack forward (with the hoses still connected too)?
  • Will there be enough room to get the bushes out?
  • How hard will it be to remove the old rubber bushes?
  • Do the new bushes need to be bench pressed into the rack or would a G-Clamp do the trick?
All the best.
Neo
Neo7 is offline
post #10 of 14 (permalink) Old Yesterday, 02:51 PM Thread Starter
Neo7's Avatar
Quoted: 27 Post(s)
Hi Art,
Just seen your reply... thanks.
Yes the rack is moving from side-to-side a few mm as the steering is rocked. ... I will recheck the bolts today thanks.
All the best.
Neo
Neo7 is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jac9f
