So I went to Big O Tires in Loveland Colorado to get my free rotation and Balance on my 2002 ML 320 and was told that the front passenger wheel bearing is loose as a goose.
Later that afternoon I had an appointment with my Benz technician to replace a door lock actuator. Joey Lopez owner of Lopez Mercedes Specialist told me to acquire a new hub as I also already have purchased the wheel bearing and seal and retaining clip, and today I also purchased a new lower ball joint, next week my new hub from World Pac will be paid for and then it's time for my Benz tech to remove and replace all of the above referenced parts so everything on the passenger front will be new and tight.
In November of 2015, I replaced all tie rods both inner and outer, and in September of 2016 I replaced the passenger front axle and input shaft seal and did a front differential service with Lucas 75 W 90 full Synthetic fluid and a tube of diff fluid additive.
If anyone is looking for a great deal for a new replacement half shaft axle I got mine from NAPA, for like $80.00 + tax Mercedes Stealership wanted $1,500.00 for just the part. NAPA NEW AXLE HAS LIFETIME WARRANTY AND Is MADE IN USA!
