2002 ML320 (W163) will not start please help! - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 04-20-2017, 11:02 AM Thread Starter
Date registered: Dec 2010
Vehicle: 2002 ML320
Quoted: 4 Post(s)
I will start off by saying thanks to everyone in the forums I have learned a lot while reading all the posts. Now on to my issue.
I have replaced a 15 year old battery ( I know WOW!! it lasted this long) and now she wont start or crank.
Here is what I have done thus far (thanks to the forum)
1. checked relay and jumped pins to turn over the starter (good), checked voltage when the key is in the start position on the relay (nothing)
2. Car verifies key and lets me turn it all the way on ( I have used 2 other keys as well all same result)
3. checked all fuses (good)
4. all dash lights stay lit once key is in position 2
5. will not go out of park unless I use the hidden button ( on the dash the place where it says what gear you are in says nothing)
6. swapped around relays
Thanks in advance.
n3o23 is offline
post #2 of 18 (permalink) Old 04-20-2017, 11:14 AM
art_arev's Avatar
Date registered: May 2013
Vehicle: ML 500 2002 RHD, ML55 AMG 2003 RHD
Quoted: 585 Post(s)
Send a message via Skype™ to art_arev
Obviously, you have codes due to the battery failure. Scan the car & erase them. Then try again.
vvrjrlaw likes this.
Art
art_arev is online now
post #3 of 18 (permalink) Old 04-20-2017, 11:20 AM Thread Starter
Vehicle: 2002 ML320
Quoted: 4 Post(s)
I tried a el cheapo code reader that works on my sisters ML and it fails to connect. I have also used a Bluetooth one with same results. Should I spend the 130/hr the nearest MB dealer quoted me and get the car towed there?
n3o23 is offline
post #4 of 18 (permalink) Old 04-20-2017, 11:55 AM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 135 Post(s)
Do you have volt meter? Test light? Check all fuses first.
Do not tow it to dealer.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #5 of 18 (permalink) Old 04-20-2017, 12:13 PM Thread Starter
Vehicle: 2002 ML320
Quoted: 4 Post(s)
I do have a voltmeter and have tested all fuses in the car even the ones by the passenger door.
I can make a test light if that would help.
Thanks again
n3o23 is offline
post #6 of 18 (permalink) Old 04-20-2017, 12:28 PM
art_arev's Avatar
Quoted: 585 Post(s)
Can you check again for continuity on F10, F13 & F19
Art
post #7 of 18 (permalink) Old 04-20-2017, 01:47 PM Thread Starter
Vehicle: 2002 ML320
Quoted: 4 Post(s)
all 3 show a dead short tested from just the tops then removed each and every one and retested.
n3o23 is offline
post #8 of 18 (permalink) Old 04-20-2017, 02:26 PM
Witek_M's Avatar
Quoted: 135 Post(s)
Do they have voltage?
Any spills in to the shifter? Any arcing events during battery replacement? Any jump start events.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #9 of 18 (permalink) Old 04-20-2017, 02:48 PM Thread Starter
Vehicle: 2002 ML320
Quoted: 4 Post(s)
no voltage on f10 or f19.
I did jump it the day before and it started fine all day.
When I changed the battery there was a spark.
n3o23 is offline
post #10 of 18 (permalink) Old 04-20-2017, 03:39 PM
Witek_M's Avatar
Quoted: 135 Post(s)
Small spark when connecting battery is fine. Welding arc is not.
What is production date?
When quoting fuses name the fuse box. F1 is under hood F2 is on right kick panel.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
