The hoses between the oil cooler and the oil cooler radiator are partly rubber and partly metal. The metal part from one line is leaking coolant. There's a little hole where it is attached to the frame, probably because of constant rubbing this attach.
Can these metal lines be replaced seperately or do i have to change the complete lines. I can not find parts on the web. Does anybody have part numbers?
Thanks.
Thanks.
