Intermittent BAS/ESP light and code 1025-003 … - Mercedes-Benz Forum
post #1 of 66 (permalink) Old 03-10-2017, 08:06 AM Thread Starter
Date registered: Jun 2016
Vehicle: ML 55 2000
Quoted: 40 Post(s)
I have been having this issue for the past couple of weeks. Brake light switch has been replaced recently and codes read by STAR. Code 1025-003 was found and as per MB instructions was removed. Light stayed off for couple of days and has returned though intermittently.
Today while driving and light braking it seemed the ABS engaged (not 100% sure) but something did act on the brakes for the vehicle to almost stop even though the situation did not warrant the ABS or whatever to kick in.I was on a straight road and trying to slow down for an impending turn.
I have read thru the forum as much as I could with ECU, Sensors etc.. Like to know the best possible next step?
sstomcat1 is offline
post #2 of 66 (permalink) Old 03-10-2017, 12:47 PM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 , 2008 C200k Elegance 2006 C180k sports(sold)
Quoted: 496 Post(s)
Pull the connector off the ABS pump and check it for any corrosion. Give it a good clean with electrical contact cleaner. Make sure your washer bottle is not leaking onto the connector.
mattml430 is online now
post #3 of 66 (permalink) Old 03-10-2017, 01:05 PM Thread Starter
Vehicle: ML 55 2000
Quoted: 40 Post(s)
Great will do this weekend and revert. Thanks!
post #4 of 66 (permalink) Old 03-10-2017, 02:46 PM Thread Starter
Vehicle: ML 55 2000
Quoted: 40 Post(s)
Happened again while driving back from work, this time the traction control kicked in (the triangle was flashing) and ESP/BAS light came on.
post #5 of 66 (permalink) Old 03-10-2017, 04:58 PM
mattml430's Avatar
Quoted: 496 Post(s)
While your in there pull the inner guard and check to make sure no wires have chaffed through on the loom to the pump. I had that happen to a friends ml.
post #6 of 66 (permalink) Old 03-11-2017, 11:03 AM Thread Starter
Vehicle: ML 55 2000
Quoted: 40 Post(s)
Cleaned and checked put back on, light is still on..
post #7 of 66 (permalink) Old 03-11-2017, 11:38 AM
art_arev's Avatar
Date registered: May 2013
Vehicle: ML 500 2002 RHD, ML55 AMG 2003 RHD
Quoted: 585 Post(s)
Send a message via Skype™ to art_arev
You might have to replace your ESP module. C1025 is a CAN fault within the ESP module.
Art
art_arev is offline
post #8 of 66 (permalink) Old 03-11-2017, 01:02 PM
mattml430's Avatar
Quoted: 496 Post(s)
Searching about this code and it can also point to brake light switch or wheel speed sensors. Did it start recently after you replaced the B/L switch?
Was it adjusted properly after installation.
Hope this is not to blurry. Art or Jim might repost it as I can't copy and paste these original documents.
post #9 of 66 (permalink) Old 03-11-2017, 04:10 PM Thread Starter
Vehicle: ML 55 2000
Quoted: 40 Post(s)
Is this plug and play ? or there needs to be some coding involved?
It started before I replaced the brake switch as a potential solution.
post #10 of 66 (permalink) Old 03-11-2017, 04:17 PM
Date registered: Jul 2005
Quoted: 1145 Post(s)
If you replace the ESP module with a used one you will most likely have to clear the fault codes after it is back together.
Noodles is offline
