anyone do this at home? I know u need a high pressure device to do this... can someone give some instructions how? does each wheel have one or two bleed screws? thankS!
If you are not the mechanic type and never done brakes before leave it alone, you can end up very easily having air in the lines or cylinders or having bleed valves leaking, at best you end up with very spongy brakes and at worst the worst.
