Old 04-03-2002, 07:54 PM   #1 (permalink)
James
Posts: n/a
Bose system in 2002 ml
Hello gang,<br> Could someone please clarify how many speakers there are with the Bose upgrade with CD changer option and where the speakers are within vehicle.<br> Thanks!<br> James
Old 04-03-2002, 08:12 PM   #2 (permalink)
MikeH
Posts: n/a
Re: Bose system in 2002 ml
There are 9 speakers + 1 SW under the driver seat. 4 speakers on each doors + 2 front tweeters on the A pillar + 2 rear tweeters on the D pillar (trunk area) + 1 under the front passenger seat facing the door. <br> <br> Please correct me if I'm wrong.
Old 04-03-2002, 08:22 PM   #3 (permalink)
MBLady
Posts: n/a
Do you know the 2001 ML430 model? are there the same amount of speakers and locations?
Old 04-03-2002, 08:37 PM   #4 (permalink)
MikeH
Posts: n/a
<br> I know my friends 2001 ML only got 6 speakers + 1 SW under the front passenger seat. The 4 speakers are on each doors, but I'm not sure for where they put the 2 tweeters. It's possible they are embedded with 2 front speaker. <br> <br> Like usual, if someone knows better, please correct me.
Old 04-04-2002, 01:24 AM   #5 (permalink)
Drew
Posts: n/a
Yes, that is correct...
The pre-'02 Bose system has coaxial front speakers, with built in tweeters on top of the woofers. There are actually techically only 4 speakers + one subwoofer.
Old 04-04-2002, 10:33 AM   #6 (permalink)
MBLady
Posts: n/a
Re: Yes, that is correct...
Can the sound be improved without modification? Can speakers be changed out with better ones?
Old 04-04-2002, 11:42 AM   #7 (permalink)
MikeH
Posts: n/a
With or w/o Bose system ?
<br> I heard that Bose system needs 'all' Bose speakers to function properly. Again, I'm not so sure. You can post your question to Audio/Video forum.<br> <br> But if you don't have Bose system, I guess you can always change the speakers to better ones.
Old 04-04-2002, 11:48 AM   #8 (permalink)
Drew
Posts: n/a
Changing speakers is counted as a modification, isn't it? :-)...
But yes, you can do that, should you wish. I've heard that because of the Bose electronic equalisation though, you might not hear that much of a difference. But you can always try, of course.
Old 04-05-2002, 11:03 AM   #9 (permalink)
Nitin
Posts: n/a
I thnk the pre 2002...
has a 6 speaker system + SW. I have the 01 ML430 and noticed a speaker on the bottom of the front passenger seat facing the door. I could not locate the sixth speaker but I am sure it is seperate from the ones attached on the doors. I could thus account for 5 speakers and a SW.
