Old 03-26-2002, 01:13 PM   #1 (permalink)
Dave
Posts: n/a
What is a "self adjusting hydraulic valve lifter"...
What is a 'self-adjusting hydraulic valve lifter' and how does it work?
Old 03-26-2002, 04:17 PM   #2 (permalink)
Tom
Posts: n/a
Fig. 12-26 in http://www.tpub.com/machines/12j.htm
Old 03-26-2002, 05:31 PM   #3 (permalink)
sosh
Posts: n/a
Re: What is a
Most all hydrallic valve lifters are self adjusting
Old 03-26-2002, 06:31 PM   #4 (permalink)
Andrew
Posts: n/a
Re: What is a hydraulic lifter and how does it works.
As opposed to a mechanical lifter, a hydraulic lifter operates at zero clearance, as the lifter body rest on the cam it is charged by the oil pressure of the engine, the pressure is kept by a check valve, working on the principle that oil can not be compressed the plunger inside lifts or pushes the valve as the body is riding the cam lobe, a certain rate of oil leak is built into each design, the charging and leak rate allows the plungers to adjust to cam wear and other valve components and gap disparities due to temperature changes.<br> <br> The simplest I can get, hope it helps.
Old 03-27-2002, 07:44 AM   #5 (permalink)
Dave L.
Posts: n/a
Right Andrew, thats why you may hear some clacking when you first start the vehicle...
Old 03-27-2002, 02:43 PM   #6 (permalink)
Andrew
Posts: n/a
Dave, correct, lifters are extremely sensitive to contaminants in the oil.
