And the journey begins for you. Good stuff!!!! I think there is a pigtail adaptor for that you will probably find that on eBay as well. I got the same lights of eBay from the seller fishcake. My LED driver died in them in one after about 18 months but I did a complete LED upgrade to 3w LEDs and drivers in mine they a as bright now as the factory ones. The rest of the headlight has been great and still is their getting on to 2 to 3 years old know. They where the Bi xenon ones.
Thanks for the info. I've spent the past two hours searching through Ebay and I cannot for the life of me find the adapter you're talking about... Any chance you have a link handy?
Sorry Fai i don't as i didn't need one myself when i upgraded but one of the guys here who have used one might be able to help hopefully. Send the seller of the lights a message as they might have them or know where to get them.
Hmmm. I've had all of 2 days to look at my ML55 so I'm not sure of my facts (and I'm not with the car this week). But I think my factory Xenons may have self levelling motors in them to adjust the up/down trim on the beam ?? If this is true, and you have the same, are you banking on losing that when you swap over to projector lights?
What do you mean by "DRLs built in". I know DRL means Daytime Running Light but what do you mean by "built in"? Do you just mean the low beam lights are switched on automatically in low light conditions - like in the post face-lift MLs - as this feature entails a light sensor and switching which is external to the head light unit.
HNY Rob the lights he's looking at still have that feature. They are also bi xenon and the LED strip is under the projector.
Pretty much all the information you need is here in this forum. I updated my '01 ML430 with a pair of '02+ Xenon projector assemblies and encountered the wiring change requirement. The headlight connectors are the same, but for some reason a few of the pins were re-assigned in the connector year to year. Instead of using an adapter I rewired the headlight connector itself, which isn't all that difficult to do once you find good information (what pin needs to go where). I don't remember more than one wire needing to be relocated (but that was years ago now). With the appropriate tool, the pins of the connector are removable and then relocatable, but if you are not comfortable with taking on this job or have never done something similar, I would advocate you search for the adapter. Years ago an outfit called Performance Products used to carry this adapter assembly (see pic) for their aftermarket headlight unit.
Pre-Projector M-Class headlight connector pinouts
All MY2000 M-Classes have these two headlight connectors
Some versions may not have all of the wires/pins in the connectors
Eight position connector with two rows of four
pin A pink wire low beam
pin B orange wire range adjustment motor
pin C blue wire range adjustment motor
pin D - not used
pin E tan wire ground
pin F blue marker lamp (sometimes called city lights)
pin G white high beam
pin H gray foglamp
Three position connector with single row of three
pin A tan wire ground
pin B blue wire standing/parking lamp
pin C green wire turn signal lamp'.
I have part number p82-667 I have a 2000 ml55 with bi xenons. Want yo do projector lights. My newer ebay lights only have 2 plugs on back my factory lights have 3 the pig tails did not work at all. And what do I do with the third plug.
Not good practice to post the same question on two threads by other members just 20 minutes apart. It won't get you a quicker response - it just splits the discussion and will likely diminish the value.
If you have a question, post it once and wait patiently for some help to arrive.
Also, consider starting your own thread if your question is significantly different from that of the person who started the thread, or is likely to divert the discussion from solving their original problem.
Those eBay lights are not made to work with a model that already has factory Xenon lights.
Hopefully you can send them back if you already bought them.
My eBay lights have the levelling adjustment motor. It is manually controlled with the switch next to the steering wheel though. Not auto levelling so I imagine you would be Able to make it work with a bit of circuit testing.
Renn,
Ebay answered your question:
IF you have Factory Xenon Headlights:
* For the Originally Xenon equipped car owners, this set of headlight is NOT for you.
Noodles answered your question on this tread...
RJV answered your question on the other tread..
Please dont open a new tread about the same issue...
I normally would have deleted it but was reading from bottom to top with older posts first and running my giant Xerox iGen for a perforated postcard job. I was all over and had to log in a couple of times. So once I saw Rob answered it I repeated the answer here.
If the double posts were not part of existing threads with useful info one of them would have been gone.
Just had one in the W164 forum start a new thread about the same thing three times in a row. I deleted two of them. Then got a hostile response so that newbie is gone.
Renntech55 is learning the site and we should all stick together as W163 owners. It is the last of the body on frame built mid size true SUV with much better than SUV manners on paved roads. A rare beast and if not abused basically indestructible.
I plan to add 2005 ML500 to our household very soon. Just looking for that perfect deal. My wife really wants a G55. I can't afford that at this time.
So I guess the string begs the questions: (I have a 2000 ML55, original headlamps, self leveling motors).
I don't like the old look. I want the new look. However I don't want to spend a lot of money (I clicked on the link above and do not think that new headlights (at least those ones) are worth paying essentially 10% of the cars value.
1. What is the best solution to get the new look?
2. Does the pig tail work or does it not and is it available?
3. What is the cheapest (viable) solution?
4. I bought Depot Projection Replacements. Obviously they don't work. I cannot return them. I would like to try the pigtail option, give up the self leveling thing and make them work. Otherwise I will post them here for sale for what I paid for them.
I thought this would be the easiest upgrade but boy was I wrong!
