I took my car to an indy shop that I always go to and asked them to replace my fuel filter since I'm at 110k miles on the original filter. The mechanic said the fuel filter on ML's don't ever need changed and basically talked me out of doing the work. I thought this was strange since he could have made money off it. About a week later I decided I would have it done anyway and took it in to a different mechanic, and this one told me the same thing and I left without having it replaced. Has anyone else ever heard of this?
You thought right. I have a 05 500 and the book says to do the FF every 60K/5yrs to maintain peak performance. However, my maintenance booklet calls for FF replacement at 65K, 130K and 195K....every 65K. If you do a lot of off roading/drive in dusty environments, I would suggest 30K intervals.
I didn't believe him, but thought I would ask. I only go there for PITA items and haven't had any fluids changed there. I was trying to avoid the dealership since they wanted $600 to replace the FF.
I don't know what is involved with replacing a FF on an ML, but $600 for the FF sounds steep, very steep. Find and independent shop in your area to do it. Most of it is labor. Buy the FF yourself and if you don't trust independents (if you have one available), ask your local Nissan/Mazda/whatever to do it for you. The task is same but the cost will be less.
I had to change mine at 90k because it was clogged. The truck wouldn't run. It was a complete pain to do it and I ended up breaking the plastic clip that attached to the pump thereby requiring additional parts. Not a hard job, just very very difficult to get to because of enclosed space. You have to remove the rear wheel and a cover under the back seats... possibly the wheel well as well..
That was 150k ago and no problems since. It's likely that I was getting bad/dirty fuel for a while there.
Thanks for that testimony - it is mostly labor (like we all didn't know that!). That is why I advise the OP to get the part and use someone else with a lower labor rate to do the job - I do that all the time because it's my $ anyway and I don't like DIYs that involve fluids.
I don't think there is such a thing as a filter that never has to be replaced. I mean all filters are meant to filter somthing, which means they accumulate that something, and they cannot do that indefinetly since their capacity has to be limited by their size and all. That's pretty basic common sense, tell me if I'm wrong. Having said that, I've never replaced mine, it may have been done at one time before, but not during the last 4 years or so. It's under the plastic wheel well cover, easy access once you manage to pull that cover off, gotta put it on jack and take the wheel off naturally, but I don't know what's involved into dismantling it. I'm sure it's not worth $600 of labor, though the filter itself costs like seventy bucks. Still, even $500 is a crapload of money for a freakin' filter.
Whats the idea with the loop line?. Is it just to stop kinking/bending the engine feed line so it would fit the new size filter.
It is also advised to install new lines to the pump. Is that for the same reason i.e they are longer than the standard lines?.
The original filter was smaller and the three lines were designed to fit that smaller filter.
When they extended the length of the filter and did not devise the loop line, the feed line and the return lines from the pump would be pushed to the right causing stress on those lines.
Thanks all. I am still on 0201 old filter at 138k and i am getting pissed with the fuel gauge so will be doing all at some point. Got the filter and fuel pump. Just need the lines and a better reason to do it.
quick question my fuel filter was replaced at 65,000 with the larger filter a163-477-07-01. does that mean my fuel lines were updated as well? i believe i should be able to see it when i rotate my tires on the frame well, but if you can only put larger filter only w/ updated lines cool, but i dont have anything to say it was updated
Got a question, are the upgraded filter and 3 lines standard on '02 and up ML 320 models. I just found a nice black '02 at a scrap yard with some parts I need. Figured I would grab that filter as well if someone here can confirm, Thanks
i would think so, as they usually change one number on the filter higher, but let the experts on these machines verify it for you. thank you 43sqd and Mike's ML for your help again. took wheel off and cover,because i wasn't sure w/my lighted mirror what i was looking at and i do have the line loop which i was looking at w/the mirror. so around every 65,000 miles replace it so it is do on my ml soon. thanks again as i am very much still learning this wonderfully built ml. every body is great on this forum:thumbsup:
But what if saving $50 for a $5 used one doubles the job? IMO it is not worth risk. This filters are so annoying to replace that I would only put new ones in.
Mahle makes a great OEM replacement and they are about $50-55 all over the interweb. Now getting the lines is another story. Getting them for $5 is a steal.
694.8K members
