Vibration Damper - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 11-21-2012, 02:26 PM Thread Starter
motohunter4's Avatar
Date registered: Dec 2010
Vehicle: 2003 ML 500, 1985 735i Euro
Quoted: 2 Post(s)
Vibration Damper
While replacing the transmission lines I noticed the vibration damper has a slight wobble. The engine runs smooth (I can set a drink on the intake and it stays). Does it need to be replaced?
May the 'Schwarz' be with you.
motohunter4 is offline
post #2 of 17 (permalink) Old 11-21-2012, 02:46 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
If it's very slight, then assuming the P/N is not in the suspect group and the rubber shows no signs of deterioration, I'd be inclined to leave it in place and simply check it regularly.
Good luck.
Check Codes is offline
post #3 of 17 (permalink) Old 11-21-2012, 03:11 PM
pte
pte's Avatar
Date registered: Sep 2006
Vehicle: Kleemann Headers , PTE Cams , 05 ML-500 SE
Quoted: 22 Post(s)
Harmonic Balancer
It really should not Wiggle. Run out Radially is up to 0.0196 ths . Run out Axially is up to 0.0118 ths. There are noted for going bad and are replaced quite often. At one time there was a Recall , and a SB. The R & R is not a hard job. But requires a Holding fixture , Which can be brought on E-bay for less than $40.00. Do A search here you will find torque specs. You must used a new bolt , It is a stretch to Yield. You can Buy a new H/B from Mercedes or a aftermarket from a Fluidampr retailer for around $400.00
Cheers _PTEngineering
pte is offline
post #4 of 17 (permalink) Old 11-21-2012, 03:19 PM Thread Starter
Quoted: 2 Post(s)
That's what I was thinking, thank you. If I do replace it, is the front seal replacment as easy as pry out and pound a new one in? It doesn't leak oil, but I figured if you are already in there why not?
post #5 of 17 (permalink) Old 11-21-2012, 03:24 PM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 923 Post(s)
Well let me put it this way, the vibration damper has gone through six revisions since 1998 and it is not pretty when the damper separates. Fan blade, fan shroud, belt, radiator and often the A/C condenser.
43sqd is offline
post #6 of 17 (permalink) Old 11-21-2012, 03:46 PM
megadamp's Avatar
Date registered: May 2008
Vehicle: 1999 ML320
Quoted: 69 Post(s)
Are we talking harmonic balancer here or something else?.
megadamp is offline
post #7 of 17 (permalink) Old 11-21-2012, 03:47 PM
Quoted: 923 Post(s)
One in the same.
43sqd is offline
post #8 of 17 (permalink) Old 11-21-2012, 03:50 PM
megadamp's Avatar
Vehicle: 1999 ML320
Quoted: 69 Post(s)
I wish some would not confuse things and use the correct name. I'm sure your going to educate me now 43 on some technicality in law.
megadamp is offline
post #9 of 17 (permalink) Old 11-21-2012, 03:54 PM
megadamp's Avatar
Vehicle: 1999 ML320
Quoted: 69 Post(s)
By the way mine has the dreaded 0000 part number and has been fine for 130,000 miles. I think in hot climates it has problems with the glue. Infact inchcape mercedes parts online lists it as a part for sale or they did last time i checked. No where near $400.00 dollars. I think £60.00 but would poss decline that part number.
megadamp is offline
post #10 of 17 (permalink) Old 11-21-2012, 04:24 PM
pte
pte's Avatar
Quoted: 22 Post(s)
harmonic Balancer
well at the transmission, end , the torque converter is bolted to a Flex plate / flywheel. maybe the op will tell us which end of the engine he is looking at
pte is offline
