engine starts for 2 second then stops - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 11-19-2012, 08:31 AM   #1 (permalink)
Date registered: Nov 2012
engine starts and runs for 2 seconds then stops.But if wait 5 seconds in acc position then starter dont run.But if immediately turn key then engine runs for 2 seconds then stops.Please help.And please effort do understand what i wrote.because my english is bad.
biturbo is offline   Reply With Quote
Old 11-19-2012, 08:58 AM   #2 (permalink)
W126 Dr.MB's Avatar
Date registered: Aug 2010
Vehicle: 1988 Mercedes 560SEC
Hello, it sounds like your fuel pump is going bad. But I think at acc position, your car is a state where the electrical comp. assume the car is running or about to run so the fuel pump kicks in and pumps gas. But if fuel pump is out, then no gas is pumped. But once you turn it on, it forces to suck gas slightly then stops which obviously stalls the engine. Good luck.
Sent from my iBenz
W126 Dr.MB is offline   Reply With Quote
Old 11-19-2012, 11:30 AM   #3 (permalink)
Oeschj's Avatar
Date registered: Oct 2010
Vehicle: 2000 ML430
What type of vehicle are we talking about here? Year and Model would help.....
Oeschj is offline   Reply With Quote
Old 11-19-2012, 12:26 PM   #4 (permalink)
oh sorry.model w 163
Old 11-19-2012, 12:42 PM   #5 (permalink)
But if it is pump then why starter dont run after waiting in acc position?Thanks in advance
Old 11-19-2012, 01:09 PM   #6 (permalink)
Oeschj's Avatar
Vehicle: 2000 ML430
I understand its a W163. WHAT YEAR AND MODEL (ML 320, 430, 55, 500..)???
An let me make sure i understand correctly. If you try to start by just normally turning the key to start for about a second, it runs for 2 seconds and dies. If you hold the key down for 5 seconds trying to start, it does nothing?
Old 11-19-2012, 01:32 PM   #7 (permalink)
W126 Dr.MB's Avatar
Try to take a video of exactly what's going on at both straight turning on and then a part where you put on acc first. Good luck
Old 11-19-2012, 01:51 PM   #8 (permalink)
Date registered: Jul 2005
Vehicle: 99 ML430, 90 300E, 05 E500 4matic Wagon
Once the key engages the starter it will only do it once before you have to turn it back to position 0 and then restart. If you are not returning it to position 0 it will not crank the starter.
Noodles is offline   Reply With Quote
Old 11-19-2012, 05:48 PM   #9 (permalink)
Date registered: May 2008
Vehicle: 1999 ML320
Does the red light in the middle of the fasia flash more than once when you install the key.
megadamp is online now   Reply With Quote
Old 11-19-2012, 10:39 PM   #10 (permalink)
At first thank you for attention and kindness.Model ML 320 1998.Engine pretends to run for one second if you start directly(instantly).But after waiting in acc position starter does't sound naught.
Bookmarks
