ML320 Transmission Problems - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-08-2012, 05:31 PM Thread Starter
Date registered: Jun 2012
Vehicle: 2000 Mercedes ML320
I just changed all my mounts on my 2000 ml320 (motor and transmission). The car was working perfectly for about an hour, but then i tried to put my transmission in Drive, the Gear Lever would be half an inch from the Drive Position but it would still be in the Drive Gear. The car still drives fine but i can't use the manual shifting controls. I will post a picture so it will be more clear.
Thanks
Ali5057 is offline
post #2 of 5 (permalink) Old 06-08-2012, 05:33 PM Thread Starter
As you can see, the Transmission is in Drive but it is half an inch from the original spot.
Ali5057 is offline
post #3 of 5 (permalink) Old 06-08-2012, 07:02 PM
megadamp's Avatar
Date registered: May 2008
Vehicle: 1999 ML320
Quoted: 69 Post(s)
Did you do the tranny mount first?. Maybe you bent something on the mount or underneath if you did it in that order. Shift lock cable?.
megadamp is offline
post #4 of 5 (permalink) Old 06-08-2012, 07:58 PM
Date registered: Jun 2009
Vehicle: 2000 ML320; engine number 30 633407; last 6 VIN 172300
Quoted: 21 Post(s)
There were a few posts on here from people who warn to keep the truck in neutral when doing the engine mounts and lifting the engine, otherwise you can supposedly bend or break some sort of link. I put mine in neutral to be on the safe side. Hope that didnt happen to you.
Amopower is offline
post #5 of 5 (permalink) Old 06-08-2012, 11:17 PM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 879 Post(s)
Go underneath the truck and locate the shifter rod #26 where it attaches to the shifter arm and see that the bushing #6 is in place inside the shifter arm.
If it is , remove the rod from the shifter arm and see if the problem remains. If the problem remains you will have to bend the the shifter arm back into place.
If everything is in order at the shifter, then you will have to adjust the shifter rod at the transmission.
43sqd is offline
