ML320 PO170 and PO173 error codea - Mercedes-Benz Forum
post #1 of 92 (permalink) Old 10-08-2011, 08:33 PM Thread Starter
Date registered: Oct 2011
Vehicle: Mercedes Benz 2000 ML320 V6 3.2L Gas
Angry ML320 PO170 and PO173 error codea
Bought 2000 MB ML320 3.2L GAS with 188K (about 117000 miles) on it. Oil check light was on! I replaced Oil level sensor with Mercedes genuine Oil level sensor from Discount Body Parts, that solved the problem light went out it's OK. However, check Engine light is still on and I am still getting PO170 and, PO173 error codes! so far I replaced MAF with Generic MAF sensor from SOCAL MERCEDES PARTS I cleared the codes several times but light comes right back on after SUV is driven 10-15 miles!! I still got the old MAF sensor should I try to clean it out first (can anyone suggest a cleaner?) also is generic part OK?. What else might be triggering this "Check engine" light to glow menacingly like this? ML320 is running great but fuel mileage is poor. Any help would be greatly appreciated!! frustrated in Hamilton, ON.,THANKS
Seacap is offline
post #2 of 92 (permalink) Old 10-08-2011, 09:49 PM
Date registered: Jul 2005
Quoted: 1042 Post(s)
CRC MAF cleaner. Most stores carry it.
If you have not had ALL MB SPECIFIC codes read then a pro grade or MB SDS scan tool will be needed
to pinpoint the problem. Throwing more parts at it is futile at this point.
Noodles is offline
post #3 of 92 (permalink) Old 10-08-2011, 11:29 PM Thread Starter
Thank you for prompt reply. When I got the car couple of months ago I replaced spark plugs and installed KN air filter this made no difference light CEL (what does that stand for?) was still on, '00 ML320 was scanned by qualified mechanic codes printed out all 8 pages of it, vacuum system was checked for leaks by back pressuring the system with smoke. Incidently old MAF was showing no life on the scanner but replacement caused the graph to register data immediately. Despite these heroics engine check light is still stubbornly lit up? My mechanic is baffled and actually suggested I post a thread on the website and see if other people can give us some ideas on how to put the lights out pardon the punt.
Seacap is offline
post #4 of 92 (permalink) Old 10-09-2011, 12:20 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Seriously?
Paying a mechanic to have you find out and tell him what the problem is and how to fix it is like taking food to a restaurant, giving it to the chef, and telling him how to prepare the meal...and then leaving him a tip.
There are myriad possibilities, but rule one is to take it to a qualified mechanic (defined, at a minimum, as one who doesn't send you to an internet forum to research issues so you can pay him or her to fix them).
Good luck.
Check Codes is offline
post #5 of 92 (permalink) Old 10-09-2011, 10:55 AM Thread Starter
Your point is well taken. This is my first performance engine so I need to educate myself on how to go about fixing this and possible cost involved. Qualified mechanics like the ones at MB dealer can and will relief you of hundreds of dollars if you let them put one over on you and reading other posts about PO170, PO173 nightmare I am not the only one looking for suggestions.
So far I am out MAF sensor (n/c for SDS scan) his $10K MB SDS spits out PO170 and PO173 codes. I have 8 page print-out of 2005 Mitchell Repair Information Company, LLC (this maybe SDS's software) would this contain the "ALL MB SPECIFIC codes" I need? some examples would be helpful.
Seacap is offline
post #6 of 92 (permalink) Old 10-09-2011, 11:11 AM
It is odd that he has a MB SDS and prints out Mitchell sheets. It should be printing
MB printouts from DAS/Xentry and WIS (MB lingo).
Noodles is offline
post #7 of 92 (permalink) Old 10-09-2011, 12:53 PM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 116 Post(s)
First read about DTC anatomy. Generic OBDII codes for power train management have format P zero XXX. More details here. OBDII - Diagnostic Trouble Codes - Anatomy of the DTC
Searching this forum for PO173 gets 27 hits. Searching for P0173 gets 145.
Educate yourself and your mechanic on subject of mixture adaptation and Long Term Fuel Trim. What it does, what is it for, what affects it and so forth. Here is good start. Google the rest. http://www.mercedestechstore.com/pdf...2004-01-01.pdf
Concept of power train management works same way in Mercedes and Geo or Kia. It is not something reserved for high performance engines.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #8 of 92 (permalink) Old 10-09-2011, 07:30 PM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 216 Post(s)
I would not have used a generic MAF sensor. Just my 2¢.
cmitch is offline
post #9 of 92 (permalink) Old 10-09-2011, 07:48 PM Thread Starter
Thanks for your reply. Had I joined this forum a week earlier I would have got that message loud and clear however, it may not be too late to return it yet.
Seacap is offline
post #10 of 92 (permalink) Old 10-09-2011, 07:50 PM Thread Starter
My mistake I don't know make/model number of the SDS he uses however, if you're familiar with this software there is something here that reads under heading:
SELF-ADAPTATION OF MIXTURE FORMATION AT ITS LIMIT-FAULT CODE DESCRIPTION
ME-SFI -AD07.61-P-4000-09AA
1A Fault code PO218 for right cylinder bank (PO170)
(USA Readout on generic scan tool) P2087 for left cylinder bank (PO173)
1B Engines 112, 113 as of 1/01 P2018-[1] for right cylinder bank, mixture
correction too great
PO170
Fault code P2018-[2] for right cylinder bank, mixture
correction too small
PO170
(USA Readout on generic scan tool) P2087-[1] for the left cylinder bank, mixture
correction too great (PO173)
P2087-[2] for the left cylinder bank, mixture
correction too small (PO173)
could a qualified technician seeing this readout deduce: this points to a problem and here is how you fix it !!! your input is greatly appreciated.
Seacap is offline
    Troubleshooting PO170 and PO173 codes boxermania W210 E-Class 14 10-10-2012 06:25 AM
    PO170 and PO173 error codes Seacap BenzWorld Help 1 10-08-2011 11:51 AM
    2000 CLK 320 error codes PO170 PO173 wont go away grapejellykelly C209/A209 CLK-Class 4 05-21-2011 03:02 AM
    Error codes PO170 & PO173 - ? Dadaman General Mercedes-Benz 8 04-22-2011 01:27 PM
    codes PO173, PO170 & PO446 kwiklee W163 M-Class 2 08-13-2007 07:08 PM
