Need FUSE CHART PLEASE!!! - Mercedes-Benz Forum
post #1 of 29 (permalink) Old 09-17-2011, 05:40 PM Thread Starter
Date registered: Sep 2011
Vehicle: 1998 ML320, 2010 Sprinter Pass Van, 2010 R500, 2004 SLK230
Hello,
Newbie here. I've search in the forum but came up empty .
Anyone out there with a 98 ML 320 please post a picture or chart of your fuse box cover. My cover was missing when I got the car and have not been able to locate a fuse chart anywhere online.
Thanks in advance.
John
nojodas67 is offline
post #2 of 29 (permalink) Old 09-17-2011, 06:45 PM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 97 Post(s)
There are many variants. Order cover or label from your local MB dealer using your VIN number.
If you need help update your user profile with vehicle and location info.
What's not working?
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #3 of 29 (permalink) Old 09-17-2011, 06:46 PM
Witek_M's Avatar
Quoted: 97 Post(s)
Here is one from MY2002
http://www.benzworld.org/forums/w163...ml#post3597070
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #4 of 29 (permalink) Old 09-17-2011, 07:56 PM
Vehicle: 1990 190E 2.6,.... 1998 ML320, 2005 ML500SE
Quoted: 63 Post(s)
The 98ML's have the engine compartment fuse box only.
Doesn't the 2002 ML's have both the engine compartment and passenger kick panel fuse boxes? The fuse boxes will have different fuse combinations and orientation.
Mike
Mike's ML is online now
post #5 of 29 (permalink) Old 09-17-2011, 08:20 PM
Witek_M's Avatar
Quoted: 97 Post(s)
Single post, just registered and offline.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #6 of 29 (permalink) Old 09-17-2011, 09:09 PM Thread Starter
Why does that matter? talk about being judgmental.
I know I can order a cover from the dealer...but not on a Sat. night.
I just need it to check out a few things that are not working.
thanks Mike, you are correct. I had already found that chart for a 2002, but that chart does not coincide with mine. That's why I wanted to check here and see if a member, other than myself, also owned a 1998. My daughter is going back to college Sunday night (it's her car now and she's only here on an occasional weekend) so I only have until tomorrow to sort things out for her. I just don't know why I have to explain myself when asking for something so simple.
thanks for rolling out the welcome mat, guys. (sarcastic)
post #7 of 29 (permalink) Old 09-17-2011, 09:13 PM Thread Starter
Your profile says you own a 1999...do you still have it? Fuse charts may be more similar than the 2002. 1999 may have the single fuse box.
post #8 of 29 (permalink) Old 09-17-2011, 09:24 PM Thread Starter
What's not working?
Oh...My other MB vehicles are a 2011 Sprinter 170" wheelbase diesel passenger van blue & 2010 SLK black. Other non MB vehicles, 2000 Corvette convertible (orig. owner with 8k miles on odometer), 2008 Cadillac DTS (daily driver), 2004 Dodge Ram quad cab 2500 Diesel (for home depot runs). Don't know how to update my profile yet.
On the ML, the ETS light and SRS lights are on. Also, the radio stays on all the time, even after ignition shut off. She has to remember to manually turn radio off or it will stay on for days at a time ( she found this out after a few dead battery mornings). There is also an occasional loud clicking noise from behind the center dash area.
Between yesterday and today I replaced 2 oxygen sensors (check engine light is now off), replaced a broken rear spring/strut assembly, replaced both front ball joints, jerry rigged a broken window regulator, fixed an A/C refrigerant leak, replaced both rusted out horns, replaced the malfunctioning column switch, and replaced a mangled driveshaft support bearing. So tomorrow, I had hoped to tackle the ETS light, SRS light and the persistent radio, but I needed the fuse chart to begin to diagnose the problem.
post #9 of 29 (permalink) Old 09-18-2011, 12:54 AM
Raya's Avatar
Date registered: Mar 2011
Vehicle: 1999 ML320
Quoted: 23 Post(s)
Fuse label
Here is photo from my late 98 ML320. Hope this Helps.
Name:	Fuse Cover Label.jpg
Raya is offline
post #10 of 29 (permalink) Old 09-18-2011, 08:23 AM Thread Starter
This is perferct!
Thank You!
  • Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
    FUSE CHART beavertonbenz R/C107 SL/SLC Class 55 05-06-2016 09:55 PM
    '82 500 SL fuse chart MJones R/C107 SL/SLC Class 9 09-12-2011 07:32 AM
    Help with fuse chart zft325 R170 SLK-Class 5 12-12-2008 05:56 PM
    Fuse chart roodben General Mercedes-Benz 1 12-29-2007 12:52 AM
    fuse chart oscarferreira W220 S-Class 0 09-09-2005 10:42 PM
