Just so no one tries fixing a leaking transmission electrical plug with an inferior product........
After reading posts of the URO transmission electrical plug not being up to par, I got a MB plug to compare with the URO plug previously ordered from AutohausAZ. (Had previously ordered but not installed a URO for the lastest 722.6xx addition to the family, a ML320 with 165,000 mi)
A quick visual did not show any differences. A dimensional comparison of the plug bodies with calipers showed they were the same.
However, a dimensional check of the smaller O ring showed that the URO was thinner than the MB plug by about 20 thousands when installed on the plug. The upper O ring was also thinner.
Once the O-rings were rolled off the plug bodies, the size differences became clear. (see photo)
I speculate that the smaller O ring is critical to keep ATF out of the conductor plate shroud connection (a guess) and that the larger O ring keeps ATF from leaking to the outside of the transmission. A less tight fit of the URO plug may increase the chances of ATF leaking into the connector and wicking up to the Transmission Control Module.
Glad now of spending a few extra bucks on the MB plug. Just changed it out on the ML320 (which has a transplant tranny and heaven knows how many miles). Of course, the connector plug was wet with ATF on the electrical side, and the inelastic rubber O rings were red (factory original?) Also, the new MB connector plug was slightly difficult to get the center 7mm bolt to engage than compared to the last time I changed a plug on our E420 – with a URO. Suspect that the smaller O-rings make for easier seating, but inferior sealing. And, as luck would have it, I had ordered the S430 transmission plug replaced 3 years ago from AutohausAZ, so that (URO) is going to be replaced in during the upcoming tranny service.
