SRS Light ON ...My Scanner will not Erase - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 05-23-2011, 07:14 PM Thread Starter
Date registered: Oct 2004
Vehicle: 2001 ML320 & 2003 SL500
Quoted: 14 Post(s)
Took my door panels off in order to upgrade my side view mirrors and now my SRS light is on.
Anyone know why that happen??? and how do I get rid of it.
I have this code reader ZI got off ebay.
U380 Universal Engine Scanner Code Reader OBD2'OBD II | eBay
When I run a scan it tells me I have no code errors, but my SRS light is on..What gives...
Is it because its a cheap scanner??
M_city is offline
post #2 of 22 (permalink) Old 05-23-2011, 07:37 PM
Date registered: Jul 2005
Quoted: 1011 Post(s)
That scanner will not handle the MB specific things. Another China bargain.
You will need a lot more than that to get past the basic emissions codes.
Also SRS codes are hard codes, meaning that they are stored until the problem is fixed
and then the code can be cleared. If the SRS light came on you have a an SRS problem.
I pro grade scanner or MB Star system will read the code and tell you what went wrong
with the system. It could be as simple pinched seal belt buckle wire or something as
crazy as the clock spring. Without a code you are spinning your wheels.
Noodles is offline
post #3 of 22 (permalink) Old 05-23-2011, 08:04 PM
Vehicle: 1990 190E 2.6,.... 1998 ML320, 2005 ML500SE
Quoted: 64 Post(s)
Did you disconnect the side air bags when you removed the door panels?
That will set off the SRS light and you will probably need a visit to the dealer to get things straightened out. Hopefully you will not set off the airbags.
Even the best OBD II scanners will not read nor reset the Mercedes specific SRS codes.
Mike
[EDIT: When I said "Even the best OBD II scanners" I meant the units available to the shade tree mechanics. This does not include the Snap-On, very expensive, commercial analyzers, which I would not classify as a common OBD code reader.]
Mike's ML is offline
post #4 of 22 (permalink) Old 05-23-2011, 10:51 PM Thread Starter
Quoted: 14 Post(s)
Am I right in assuming that a snap on scanner with NOT reset my SRS code????
The only way is the dealer....Just hate paying $150.00 for pushing a few button on a scanner.
The reason I ask is because I know that is the scanner my Local Mechanic has..
M_city is offline
post #5 of 22 (permalink) Old 05-24-2011, 02:59 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 909 Post(s)
Yes a Snap-On scanner will erase the code, (providing that you are absolutely sure you reconnected both air bags), but he has to access the SRS/Air Bag section on the menu to do so.
43sqd is offline
post #6 of 22 (permalink) Old 05-24-2011, 03:28 AM
Date registered: Jul 2009
Vehicle: ML 400 CDI
This tool DOES NOT work with any vehicle that uses the CAN protocol. CAN protocol is not supported.
if your car have CAN BUS protocol. please purchase U480 as below link...
bernie34fr is offline
post #7 of 22 (permalink) Old 05-24-2011, 04:28 AM
Quoted: 909 Post(s)
You didn't provide a link.
43sqd is offline
post #8 of 22 (permalink) Old 05-24-2011, 07:19 AM
Quoted: 64 Post(s)
The U480 is a basic code reader, It does support the can protocol but only scans for basic engine codes.
It does not read nor reset the SRS codes.
The Snap-On unit is a commercial, very expensive, code reader / analyzer and is not something very many people have in their garages.
Mike
post #9 of 22 (permalink) Old 05-24-2011, 08:27 AM Thread Starter
Quoted: 14 Post(s)
I am going to take off my door panels again today to make sure I reconnect the airbags in the door. Then its off to the local shop to try and get rid of the code.
I think its time to buy a pro grade scanner with all the cars I have around me.
M_city is offline
post #10 of 22 (permalink) Old 05-24-2011, 08:35 AM
Vehicle: ML 400 CDI
The link...U480 CAN BUS CAN-BUS OBD2 ENGINE SCANNER/CODE READER | eBay
But U480 is a basic code reader
    Best scanner to reset SRS warning light blueskywcc W203 C-Class 16 10-23-2011 10:20 PM
    Actron OBDII scanner- anyone want to be a guinea pig? MIL triggered by scanner. RANDY P W202 C36 AMG, C43 AMG 1 11-22-2010 07:17 PM
    Check Engine Light - Scanner Input? Tri-Star W203 C-Class 4 10-05-2010 09:15 AM
    Can someone erase this? Shane Off-Topic 4 01-26-2009 08:23 PM
    Affordable Diagnostic Scanner Scanner...? sshel96310 W140 S-Class 13 11-11-2008 09:35 AM
