What kind of Oil do you use in your ML? - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 05-16-2011, 02:35 PM Thread Starter
Date registered: May 2011
Vehicle: 2002 ML320
Looking to do an Oil change, Mercedes told me use what they do- Mobil 1 5w-40 Full Synthetic, But I've also heard since I live in Texas with the Summer Heat easily topping 100+ degrees, The oil thins so use a little thicker like a 10w-30 or 10w-40. I called a few oil change places and they all give me different answers. (0w-30, 0w-40, and more). So, whats recommended? What do you use? I've also got 120,000 miles, does that effect what kind of oil I should use?
ZEvans is offline
post #2 of 18 (permalink) Old 05-16-2011, 03:06 PM
Date registered: Mar 2006
Vehicle: 1999 ML320
Quoted: 310 Post(s)
Just about any generic bulk oil will do, such as those used by the 25$ oil change mechanics.
... and this important discussion continues.
Dooloogssst!
mlfun is offline
post #3 of 18 (permalink) Old 05-16-2011, 03:08 PM
Vehicle: '05 ML350SE
I think you have a misunderstanding of what the grades mean. The number on the right is short hand for the viscosity of hot oil whereas the number on the left is for cold oil. Increasing numbers mean higher viscosity at the temperature range. Thus 40 is 'thicker' or more viscous than 30 and 0 is thinner or less viscous than 10. For the earlier MYs, the original oil spec was 0w-40 and was later replaced by 5w-40. In some of your examples, you actually thickened the cold viscosity and thinned the hot viscosity relative to 5w-40.
Tom DeTemple
Denver
'99 ML320 traded @139k miles for---
'02 ML320 traded @45k miles for---
'05 ML350SE now at 130k miles
mickey.1430 is offline
post #4 of 18 (permalink) Old 05-16-2011, 04:54 PM Thread Starter
Vehicle: 2002 ML320
Appreciate the info. Yes I have a misunderstanding of a lot of things.
ZEvans is offline
post #5 of 18 (permalink) Old 05-16-2011, 06:05 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 119 Post(s)
The spec oil was 0W40 Mobil 1 in the US for your engine, across all MB models. This spec has never changed for the W163, but under "gray area spec" MB dealers started using 5W40 because they could get that weight in bulk drums (cheaper) since 0W40 is available only in bottles.
Interestingly, 0W40 Mobil 1 has a slightly different formulation, and slightly more serious' formulation for anti-sludge than 5W40.
When in doubt, stick the the MB spec (not gray area) and make sure you use a fleece filter (not paper).
8.5 quarts for the fill, so this oil change looks expensive, but it's good for 10K miles so what the heck.
fabbrisd1 is online now
post #6 of 18 (permalink) Old 05-16-2011, 07:52 PM
Date registered: Jan 2004
Vehicle: 2004 ML500,Sport; 2009 ACURA TSX
Quoted: 40 Post(s)
0w40 mobile 1. Not expensive consider for 10K miles. MB 1 goes on sale pretty often and i load up for next oil change.
johnma is online now
post #7 of 18 (permalink) Old 05-16-2011, 07:59 PM
boardboy330's Avatar
Date registered: Mar 2008
Vehicle: 2000 ML320
Quoted: 57 Post(s)
Send a message via AIM to boardboy330 Send a message via Yahoo to boardboy330
Rotella or Mobil 1 5w-40 is what I use...whatever is on sale when I need to swap oil. Only MB filter though.
As for recommended...that is in constant debate. I heard 0W-40 last IIRC. I'm sure searching would net you both answers on what to use and how grading of oil works.
"I'd rather peel off my skin and bathe my weeping raw flesh in a bath of vinegar than spend any time with you. But that's just my opinion. Don't take it personally."
(\__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination
2000 ML320
boardboy330 is offline
post #8 of 18 (permalink) Old 05-17-2011, 04:03 AM
Raya's Avatar
Date registered: Mar 2011
Vehicle: 1999 ML320
Quoted: 23 Post(s)
My independent dealer used Castrol Longtec. This is only available to the trade. When I asked what oil to use as a top up, I was told to use Castrol Edge as it was basically the same oil. Maybe this is just an Australian thing.
Raya is offline
post #9 of 18 (permalink) Old 05-17-2011, 08:33 AM
Date registered: Jan 2005
Vehicle: 1999 ML430
Quoted: 135 Post(s)
Mobil ONE 0W40 since day one (October 1998) on my ML430 with oil changes every 10,000 miles. I swapped over to the fleece filter as soon as it came on the market. I do my oil changes myself using the vacuum method.
I occasionally notice a little of the oil "whip" when removing the oil fill cap, but not on a regular basis. This condition seems to be tied to operating the ML on short trips around town. Whenever I take a long-distance trip and the engine is at regular operating temperature for a length of time the "whip" disappears.
I have accumulated 308,000 miles and she burns very little oil. I would not even consider any other brands/weights. Just my opinion..........
springerfever is offline
post #10 of 18 (permalink) Old 05-17-2011, 09:17 AM
Date registered: Nov 2009
Vehicle: 99 White ML320, 13 Audi S5,84 300ZX Turbo, 03 Audi A4, 03 Audi TT, 65 Ford Galaxie Conv
Quoted: 9 Post(s)
And I thought my 190K was impressive.
Just curious, how much oil does she use? I have used Mobil 1 0W40 also and use about a quart maybe a quart and a half each 10K.
lyleswk is offline
  • Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
    What kind of oil do you use? garlanduke W124 E,CE,D,TD Class 11 09-02-2010 05:11 PM
    Kind of oil you use? fenton987 W201 190-Class 39 07-16-2010 07:50 PM
    what kind of oil should I use ???? firstbenz250s Vintage Mercedes-Benz 15 03-06-2009 12:13 PM
    what kind of oil?? 96S320. W140 S-Class 5 08-08-2004 06:19 PM
    what kind of oil to use? Schnell944 W123 E,CE,D,CD,TD,TE Class 12 05-23-2004 06:44 AM
