P2001/P2600 ETC error code - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 04-24-2011, 07:08 AM Thread Starter
Date registered: Mar 2008
Vehicle: 2003 ML350, Trabant P60, VWJetta, BMWG650GS
Got my car scanned with the MB diagnostic software and this is what the printout shows under ETC:
Code
P2001 Component N15/3 (ETC [EGS] control units) is defective
Status: Current and stored
Event
P2600 The voltage supply of circuit 87 has undervoltage
Status: Event Stored
car runs fine, no lights are on and everything seems to be working ok
any idea what this means?
wife picked up car from mechanic after regular maintenance work and I won't be able to speak to him until sometime mid week.
thank you in advance
sergiu is offline
post #2 of 6 (permalink) Old 04-24-2011, 08:07 AM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 132 Post(s)
Your battery voltage is dipping below 10V during startup. Poor connections or dead battery.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #3 of 6 (permalink) Old 04-24-2011, 08:27 AM Thread Starter
Thank you Witek. Changed the battery recently, like one month ago. Had to go with Advance Auto Parts one due to being stranded away from home. Should I go back to a Bosch or whatver MB sells right now?
sergiu is offline
post #4 of 6 (permalink) Old 04-24-2011, 10:22 AM
Witek_M's Avatar
Quoted: 132 Post(s)
Most likely those codes are from that event. Just erase them and check again after few days. ETC uses non volatile memory. If new battery is ~100Ah and ~600 CCA it's fine.
MB uses AGM now which is made by Johnson Controls.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #5 of 6 (permalink) Old 04-24-2011, 10:48 AM
sgtpepperaut's Avatar
Date registered: Feb 2007
Vehicle: 02 ML 55 (SOLD: 98 & 02 ML320)
Quoted: 11 Post(s)
before you consider buying from the dealer look into a yellow top battery. They are very good batteries (i would argue the outperform oem's) and will run you about the same as the dealer will charge you for theirs.
O tempora, o mores
sgtpepperaut is offline
post #6 of 6 (permalink) Old 04-24-2011, 01:33 PM Thread Starter
Tx guys.
sergiu is offline
HELP PLEASE!! W211 2003 e320 fault code P2001 with snap on reader clg8888 W211 E-Class 9 06-09-2016 07:36 AM
Error code??? the_pharaoh_zone W164 M-Class 1 10-14-2009 02:51 PM
ml320 p2066,p2001 kantoboy W163 M-Class 2 06-16-2008 12:21 AM
Error code 18 Photoman R170 SLK-Class 1 07-07-2007 07:37 AM
Error Code...Need Help... laxman0324 W163 M-Class 9 12-23-2005 07:17 AM
