ML320 transmission problem. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-07-2011, 09:16 AM Thread Starter
Date registered: Apr 2011
Vehicle: 2001 Chevy Tahoe
Question ML320 transmission problem.
I am new to the forum.Great information.I am a transmission rebuilder in St.Paul,MN.I have a 2001 ML320 that goes to limp mode right away.It has some codes yhat keep comming back.P2066,P2066,147,051,014,P0730,P0715. I do not think there is any mechanical problem with trans,I just went through the unit.T/C,O/H kit,Filter.New speed sensors w/plate.Any ideas?Thank You.
mannerl is offline
post #2 of 4 (permalink) Old 04-07-2011, 09:50 AM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 122 Post(s)
If there are "hard" tranny codes they have to be reset by the dealer or indie SDS system.
Did you check and replace the Connector/adapter plug ? Did you check the harness for "weeping" leakage that will travel up the harness ?
Keep the faith !
fabbrisd1 is offline
post #3 of 4 (permalink) Old 04-07-2011, 11:27 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 883 Post(s)
The P2066 etc. codes are those that are reported by the ETC Module to the Eng. Control Module. But codes 014 etc. are authentic transmission codes and are therefore locked into the Electronic Transmission Control Module.
You must clear the Pxxx codes from the Eng. Control Module as usual and then access the ETC Module and clear the 014 etc. codes. You will need a professional grade scanner e.g. Snap-On, or similar to perform this.
43sqd is offline
post #4 of 4 (permalink) Old 04-07-2011, 12:37 PM
Date registered: Jul 2009
It might be worth checking the battery out. You often find a faulty battery will put the transmission into limp mode and throw up a series of error codes (not sure about these specific codes). If this is the case you need to change the battery and reset the fault codes
tony jr is offline
    Transmission problem ML320 1998 lb_35 W163 M-Class 4 12-26-2010 05:15 PM
    Transmission problem ml320 2000 Brandily W163 M-Class 8 09-25-2009 08:57 AM
    ML320 transmission problem P2203 Patamdar W163 M-Class 3 08-23-2009 12:35 PM
    Transmission for ML320 bealestreetbenz W163 M-Class 8 03-09-2009 02:28 PM
    Questions on 1998-99 ML320 transmission problem autobahnNY W163 M-Class 5 07-06-2004 04:43 PM
