2001 ML320 rough/hard start - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-04-2011, 01:31 AM Thread Starter
Vehicle: 01 Ml320
Hi all
So recently my 2001 ml320 has been acting up again. This time the car is very hard to start. Once you turn the ignition the car turns over but keeps turning over for at least 10 seconds before it finally starts. A way around this is if you turn the key to start it let it turn over for 3-5 seconds stop and then restart it it starts right up again. If you let the car sit for anything more then 10 minutes it does this. Otherwise if you shut it down and restart right after you do the above it starts right up. It is a pretty consistent issue which baffles me.
I'm guessing maybe its the fuel pump? another person suggested its the cps? I have replaced the cps in the past and was about to again, but just wanted to make sure that is a good route to go otherwise I'd be throwing $50 down the drain.
Anyone have any ideas? Any help would be greatly appreciated!
Also somebody did a hit and run on me recently and hit my front driver side fender. I have a feeling my deductible will be more than doing it myself. Anyone know where I can get a Driver Side Front Fender Silver for cheap?
Sito is offline
post #2 of 8 (permalink) Old 04-04-2011, 08:40 AM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 136 Post(s)
A aftermarket fender is like $155 (as low as 4130) I cannot comment on the quality since I have never used that part. Do a google or go to eBay.
If the starting issue happends with the engine warm, that is a common sysmptom of a CPS. In that case the OE Bosch CPS is the reliable sensor from aftermarket, no name sensors or auto retail parts store brand sensors have reported issues.
If the starting issue is with engine cold - then basic battery test, fuel and air intake cleanup needs to be done to determine where the problem lies.
Keep the faith, and provide more info so others can be more helpful.
Keep the faith !
fabbrisd1 is offline
post #3 of 8 (permalink) Old 04-13-2011, 08:48 AM
Date registered: Mar 2011
Vehicle: 99 ML320
Mines doing the same, I've narrowed it to the fuel pressure regulator in the fuel filter. Might as well do the fuel pump too...
Brent1128 is offline
post #4 of 8 (permalink) Old 12-11-2011, 02:50 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 979 Post(s)
Originally Posted by tonyscratch View Post
im having the same issue any results
Tony, you should direct your questions to the W220 forum
43sqd is offline
post #5 of 8 (permalink) Old 12-11-2011, 02:02 PM
Date registered: Jul 2005
Quoted: 1140 Post(s)
Tony's post has been placed in the W220 forum.
Noodles is offline
post #6 of 8 (permalink) Old 12-11-2011, 03:52 PM
Date registered: Dec 2011
Vehicle: 2000 s 430 2000 ml320
No my ml 320 I have a 2000 that's having the same issue as the ones stated here on this thread
tonyscratch is offline
post #7 of 8 (permalink) Old 12-11-2011, 04:16 PM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 135 Post(s)
You need to update your inventory.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #8 of 8 (permalink) Old 12-11-2011, 04:32 PM
Witek_M's Avatar
Quoted: 135 Post(s)
Most common issue with long cranking times is loss of fuel pressure in fuel rail. Fuel will leak back into tank through faulty fuel pressure regulator in filter or check valve in the pump.
http://www.benzworld.org/forums/w163...ht=check+valve
http://www.benzworld.org/forums/w163...ml#post4645822
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
Fuel Consumption/Rough Idle/Hard Start Help! WayOutWardell R/C107 SL/SLC Class 9 11-17-2008 09:05 PM
hard start, rough idle when cold. please read. joecrecca W201 190-Class 13 10-21-2008 03:33 PM
2001 ML320 rough idle cea W163 M-Class 1 03-04-2007 11:23 PM
sl500 cold start fine-short trip park restart rough idle hard start?? dpol1835 R129 SL-Class 7 01-02-2006 06:33 AM
Newbie needs help! Hard start and rough idle. djimmy31 W124 E,CE,D,TD Class 1 09-14-2003 02:53 PM
