Remove viscous fan - Page 2 - Mercedes-Benz Forum
post #11 of 25 (permalink) Old 03-20-2011, 08:28 PM
boardboy330's Avatar
Date registered: Mar 2008
Vehicle: 2000 ML320
Quoted: 57 Post(s)
Send a message via AIM to boardboy330 Send a message via Yahoo to boardboy330
I don't suggest it in this instance...but for hard to move hardware I use a torch.
"I'd rather peel off my skin and bathe my weeping raw flesh in a bath of vinegar than spend any time with you. But that's just my opinion. Don't take it personally."
(\__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination
2000 ML320
boardboy330 is offline
post #12 of 25 (permalink) Old 03-21-2011, 08:28 AM
Date registered: Aug 2010
Vehicle: 2001 ML430 Sport bought in very nice shape despite 156K miles in August 2010
Quoted: 2 Post(s)
I know the shop manual specifies removal of the viscous fan, but its entirely possible to remove and repace the radiator without removing the fan. The front electric fans come off, then the radiator comes out fairly easily with the viscous fan in place. That's the way I did mine recently, and it went as smooth as butter.
APKhaos is offline
post #13 of 25 (permalink) Old 03-21-2011, 04:50 PM
Date registered: Nov 2010
Vehicle: 2004 ml500
Sorry to be off topic, but in 163.175 model there is no viscous fan and dual fans in front .. is that a bad thing for cooling.
voidy is offline
post #14 of 25 (permalink) Old 03-21-2011, 05:33 PM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 909 Post(s)
The answer to your question is no; it is just a different system. But always keep in mind that if that single fan fails in any way, you are dead in the water and get the plastic out. They don't show info for these fans after 2003, butthis is the approx price. So be very nice to it.
43sqd is offline
post #15 of 25 (permalink) Old 03-21-2011, 06:28 PM
Quoted: 2 Post(s)
Ouch! I'm loving my nasty [but much cheaper] viscous fan all the more.
APKhaos is offline
post #16 of 25 (permalink) Old 03-21-2011, 07:17 PM
Date registered: Jul 2005
Quoted: 1013 Post(s)
At a point a 55 owner might be well served to look at aftermarket electric fans when
theirs dies. They come in almost every dimension and size conceivable and are half
the price or less than the OEM fan.
One member has already done that and got his fan from a racing supply company.
He was not "going to pay a grand for a fan!!!" as he put it.
Noodles is offline
post #17 of 25 (permalink) Old 03-22-2011, 10:23 AM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 210 Post(s)
That's exactly what I was asking/wondering. WHY he had to remove the fan since I got my radiator out of the ML430 without doing so.
cmitch is offline
post #18 of 25 (permalink) Old 03-23-2011, 09:28 AM Thread Starter
clearchris's Avatar
Date registered: Sep 2007
Vehicle: 2000 ML320 (x2)
Quoted: 73 Post(s)
You don't HAVE to remove the fan, you really WANT to. It was a much harder and more frustrating job with the fan and shroud in place.
When I put the oil lines back on, add the fluids and start it up, I give the A/C system a 50/50 shot of working because it was very much in the way because I didn't take off the viscous fan.
clearchris is offline
post #19 of 25 (permalink) Old 03-23-2011, 11:10 AM
Vehicle: 2000 ML320
Quoted: 57 Post(s)
My turbo'd miata used an aftermarket fan made for a fox body mustang install. Wired up perfectly and was $50 shipped to my house.
(\__/)
(o.O )
2000 ML320
post #20 of 25 (permalink) Old 04-02-2011, 06:06 PM
Date registered: Apr 2011
I need to remove the fan off my '99 ML430 in order to get to the belt tensioner that self-destructed. I have the counter holder tool wedged against the frame and am turning the nut on the fan counter-clockwise. The 36mm wrench measures almost 39mm and is slipping off. The torque is only supposed to be 45Nm, how is it the thing won't budge? The direction of the nut is CCW to loosen right???
sernst109 is offline
    Instructions Needed : Viscous Fan Removal (radiator fan) pdxgrease W163 M-Class 4 10-18-2010 12:39 PM
    Do I need to remove front bumper to remove viscous fan? Coolant pump arrives today HACK THT W163 M-Class 2 10-18-2010 11:11 AM
    Viscous fan clutch impossible to remove? Sergio W124 E,CE,D,TD Class 11 03-23-2009 07:21 AM
    103 Water Pump - need to remove viscous fan clutch? Bryan Colleran W123 E,CE,D,CD,TD,TE Class 2 12-19-2008 09:47 AM
    viscous clutch how to remove Guest (MBNZ) W124 E,CE,D,TD Class 2 05-28-2002 10:48 PM
