Valve Cover Gasket Leak Causing Rough Idle - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 02-18-2011, 03:59 PM Thread Starter
ewick12's Avatar
Date registered: Jan 2008
Vehicle: 1998 ML320
Question Valve Cover Gasket Leak Causing Rough Idle
I took my car in today for noises under the engine, including occasional shuddering. The noise is increased when I put all four windows down at the same time. The car also runs rough when idling and driving under 5 MPH. I took it to a regular car place, not a German-specific place. They used a Snap-on computer to read codes and found the following codes,
054 - Transmission overload protocol confirm not received
065 - Control module N14/3
120 - R/F vehicle speed sensor from ECM implausible, CAN
135 - CAN communication disturbed - engine management
137 - Transfer case control CAN communication implausible
147 - Gear imp. or transmission slipping
150 - Transmission overload protocol confirm not received
The tech wrote down the following notes,
valve cover gaskets leaking oil on plugs and plug wire connectors
ignition coil #1 cylinder breaking down
Replace: valve cover gaskets, plugs, wires, 1 ignition coil (or 6 ignition coils)
They quoted me $1,600 based on their ridiculous prices for parts. They wanted to charge $400 for an ignition coil. Their labor only price is $641.25 for R&R of valve cover gasket, spark plugs, and ignition coil. They told me I could bring in my own parts if I want but that they would only provide a warranty for the labor (for 90 days).
I'm thinking about replacing the ignition coil to see if that fixes the issue. They said the valve cover gaskets are leaking onto the spark plugs and wires. I couldn't find a good DIY on the valve cover gasket replacement so I'm slightly hesitant to do that work on my own. I'm not too thrilled about spending $700 on the car. What should I do? Also, any easy fix for the transmission/transfer case codes? I don't notice much with those issues although it shifts hard. I'm hesitant to buy a new ignition coil since the check engine light isn't on.
Hopefully some of y'all can help before I waste any money.
ewick12 is offline
post #2 of 13 (permalink) Old 02-18-2011, 04:47 PM
pcy
Date registered: Feb 2005
Vehicle: '07 C280 4matic, '06 530i, '98 ML320
Quoted: 2 Post(s)
Replacing the valve cover gaskets is not difficult. Just takes 3 to 4 hours of your time. There are no obstructions on the passenger side after you remove the air intake pipe. For drivers side, you may have to disconnect the fuel connection to the rail (after releasing the fuel pressure via the fuel pressure relief valve at the end of the rail). when you have the valve covers open, pulling the plug wires are easy to remove and easy to replace spark plugs as well.
While you have the valve covers open, you can clean the breathing chambers.
The following are some pictures taken during the valve cover gasket replacement on my 98 ML 320.
ID:	357932   Click image for larger version
pcy is offline
post #3 of 13 (permalink) Old 02-18-2011, 05:14 PM Thread Starter
ewick12's Avatar
Vehicle: 1998 ML320
Thanks for the pictures and instructions. I'm wondering if the gasket is even a problem. Shouldn't I be able to smell burning oil if the gasket is leaking? I don't smell anything abnormal under the hood. What caused you to replace your gasket?
In replacing the gasket, do I just place it where the old one was or do I need anything else to seal it? I thought I read something about silicone gel.
ewick12 is offline
post #4 of 13 (permalink) Old 02-18-2011, 05:43 PM
Date registered: Sep 2009
Vehicle: 2000 Mercedes ML55 AMG
your rough idle is due to that bad coilpack. replace it and unless your leaking a ton of oil from the gaskets, its not thatttt crucial to replace them
Brettriehl101 is offline
post #5 of 13 (permalink) Old 02-18-2011, 06:13 PM Thread Starter
ewick12's Avatar
Vehicle: 1998 ML320
That's exactly what I want to hear. It'd be a lot easier for me to wait 'til May to replace the gaskets.
ewick12 is offline
post #6 of 13 (permalink) Old 02-18-2011, 06:50 PM
pcy
Quoted: 2 Post(s)
I replaced the valve cover gaskets because oil was leaking, slow leak. That oil leak wasn't causing any problems other than messy looking engine.
There are 2 gaskets (one for left side valve cover and one for the right side valve cover). Each gasket is around $15 on-line. No other sealant is necessary; except, the sealant is necessary if you are going to clean the breathing chambers.
As Brett said above, unless the oil is leaking heavily, it is not that urgent to replace the valve cover gaskets. You can do this during summer. For now, just replace the parts that are necessary for engine to run properly (like ignition coilpacks or wires).
pcy is offline
post #7 of 13 (permalink) Old 02-18-2011, 07:14 PM Thread Starter
ewick12's Avatar
Vehicle: 1998 ML320
I searched other threads and I am still confused as to how the sealant is used. Witek M said, "Sealant is used to reseal upper breather chambers/oil separators" but I'm not quite sure where I would place the sealant. Here are some pictures of the breathing chambers.
ewick12 is offline
post #8 of 13 (permalink) Old 02-18-2011, 07:23 PM
pcy
Quoted: 2 Post(s)
You have to apply the sealant around the perimeter of those chambers. If you look closely at the perimeter of the chamber, you will see a 'channel' all around the perimeter of those chambers. You will need to apply the sealant in that channel.
pcy is offline
post #9 of 13 (permalink) Old 02-18-2011, 07:52 PM Thread Starter
ewick12's Avatar
Vehicle: 1998 ML320
Thank you pcy!
ewick12 is offline
post #10 of 13 (permalink) Old 02-19-2011, 01:36 PM
Darkmann's Avatar
Vehicle: 05 500
Quoted: 32 Post(s)
I don't believe that a leak at the valve cover gasket would lead to messing up your plugs/plug pack - the coil packs are above that gasket, I think. I think they saw a leak on the upper chamber (a very common thing with these vehicles) of the valve cover and assumed it was the VC. That upper chamber leak is a $200-$250 fix at your local dealer. Your rough idle is most likely due to the harness and not the leak. Open the hood, take the motor cover off (just pull upwards and it'll come off) look for the oil trail that go onto the coil packs - usually passenger side, in my experience. I think you'll find that the leak is from the uppper chamber to the coil packs. Let us know.
1996 Z32 TT
A 18Hp lawn mower
370Z - I want one!
Darkmann is offline
    Valve Cover Gasket Leak, Replacement JonzBenz W202 C-Class 8 02-02-2012 08:13 PM
    Valve cover gasket leak, your opinion? Rat2 W210 E-Class 6 07-12-2010 11:30 PM
    Valve cover gasket leak.... Vivanashvegas W140 S-Class 9 05-20-2010 12:13 PM
    Recurring Valve Cover Gasket leak dichronic R/C107 SL/SLC Class 4 04-20-2010 07:56 PM
    Oil leak at the valve cover gasket? Chris-CA Bay R170 SLK-Class 5 07-02-2002 05:13 PM
