ML350 Unusual Electrical Problems, HELP! - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 02-15-2011, 08:53 PM Thread Starter
Date registered: Oct 2008
Vehicle: 2005 ML350 SE; 2005 Dodge Viper; 2003 Porsche 996 Cab.; 1966 Pontiac GTO
I would like to solicit the help from the many experts out there.
I have a 2005 ML350SE. My problem began recently after the vehicle has sat for about 3 months. The problem began with windshield wiper creeping up about 1/4" increments, it will do a full sweep when it reaches the 1/3 mark. The wiper switch is at OFF position.
Next, the horn will toot ever so slightly randomly. The sound is not at full level, but rather sound like a light tap. It will honk several times each time when it honks. I checked the contact, spring, wiring, everything is normal.
Finally, my door lock will make a ticking noise, but at a faster pace than a clock's tick. It seem that the lock is trying to acuate, but failing.
All these problems seem like it's casued by micro electrial pulses. I have checked the fuse box and rotated the relays to troubleshoot and eleminate the possibilty of a bad relay.
My next step will be taking it to the stealer to have them check it out. I just wanted to know if anyone out there has experienced anything like this. Any help will be greatly appreciated.
jjyu68 is offline
post #2 of 10 (permalink) Old 02-16-2011, 02:18 AM
Date registered: Feb 2008
Vehicle: Sprinter 312 4x4, 316 4x4, 316 4x2, 316 4x4, ML270
This reminds me of a similar problem which turned out to be damage to a loom done by a mouse biulding a nest in the large grommet in the fire wall. Eric.
Eric Dodge is offline
post #3 of 10 (permalink) Old 02-16-2011, 08:37 AM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 134 Post(s)
Personally, I would check the condition of the battery... pending/borderline low voltage in the ML can bring up some very wierd electrical gremlins..I haven't seen the wiper one...but the "bliping horn".. I have seen...
Good luck - keep the faith !
fabbrisd1 is offline
post #4 of 10 (permalink) Old 02-23-2011, 09:32 PM Thread Starter
Thanks for the suggestion.
My battery is only a few months old, so that eliminated the poor battery condition theory. I think the problem might stem from the battery change. Maybe damaged circuits from improper procedures?
Now I am hearing ticking sounds from behind the dash board, similar to that of the door lock. It seems that the relay ticking noises is spreading to other electrical components.
jjyu68 is offline
post #5 of 10 (permalink) Old 03-07-2011, 11:05 PM Thread Starter
Update.
Brought the car back from the stealer. I was charged $165 for an hour of diagnostics. Conclusion: they don't know what's going on. They ask me to take the car straight there next time when the car is acting up so they can read the codes. What a waste of my time and money.
jjyu68 is offline
post #6 of 10 (permalink) Old 03-08-2011, 04:05 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 939 Post(s)
Originally Posted by jjyu68 View Post
Update.
Remove both cover the the fuse/relay box and look for rodent damage.
43sqd is offline
post #7 of 10 (permalink) Old 03-19-2012, 01:56 PM
Date registered: Feb 2009
Updates?
Any updates or more insight into the issue? My '99 ML320 is doing the exact same thing.
BIG_B1977 is offline
post #8 of 10 (permalink) Old 03-19-2012, 03:08 PM
Quoted: 939 Post(s)
Open the thread and then click and his name and send an email to him.
43sqd is offline
post #9 of 10 (permalink) Old 08-13-2013, 11:09 AM
Date registered: Aug 2013
Vehicle: ml350
help
I started having the same issue on my 05 ml350 I would like to know if you found any solution and what is the problem
nunez162002 is offline
post #10 of 10 (permalink) Old 08-13-2013, 07:27 PM
Mars478's Avatar
Date registered: Nov 2011
Vehicle: Black 1999 ML320
Quoted: 35 Post(s)
You are most likely going to receive a reply as the one directly above yours (#8).
I would start a new thread describing your issues in detail. You are more likely to get help that way
ML320: 1999, black, in dash iPad Mini, LED tails, Facelift headlights with Hella E55's, 6k bulbs, RallyCrossed, and 250k and counting.
And a few other, less reliable cars...
Mars478 is offline
    Unusual Maintenance Costs for 2009-2010 ML350 MCF W164 M-Class 43 02-15-2012 09:30 PM
    Electrical Problems! yoffer W210 E-Class 14 10-01-2010 07:47 PM
    electrical problems? LesPaul2510 C208/A208 CLK-Class 4 09-07-2008 06:44 PM
    Electrical Problems jsupstarz R170 SLK-Class 0 05-22-2007 09:46 AM
    electrical problems... djplasticfork W163 M-Class 1 05-06-2003 08:24 AM
