Catalyst monitor never gets ready on OBDII after Oxygen sensor change - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 01-10-2011, 03:33 PM Thread Starter
Date registered: Jan 2008
Vehicle: 98 ML320 7 Seats, all options 01' S500
Quoted: 6 Post(s)
Had a code for Driver side O2 sensor. Never changed them since they new (13 years). So I changed the both front 2 with Bosch 17382. Reset the code. However, every OBDII monitor is ready except the Catalyst monitor after one month 2000 miles drive. No code except the not ready "c" icon on my OBDII. Anything wrong here? Am I missing some steps? Thanks!
idahombz is offline
post #2 of 7 (permalink) Old 01-10-2011, 04:38 PM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 131 Post(s)
It takes ~10 minutes at 50 mph on level road with minimal load changes. Do one run, turn key off for >10 seconds and repeat.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #3 of 7 (permalink) Old 01-10-2011, 05:09 PM Thread Starter
Quoted: 6 Post(s)
repeat once?
idahombz is offline
post #4 of 7 (permalink) Old 01-10-2011, 07:41 PM
Witek_M's Avatar
Quoted: 131 Post(s)
Repeat once. Turn key off for >10 seconds, back on then read results.
In most states car passes emissions check with one monitor not ready.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #5 of 7 (permalink) Old 01-11-2011, 05:13 AM
mbenz80's Avatar
Date registered: Dec 2009
Vehicle: 1999 ML320
Quoted: 6 Post(s)
Was the cat. monitor ready before the O2s replacement?
I've always thought that the monitoring is done by the rear sensors.
I just changed (couple months back) both of my original front sensors, never even check with OBDII since I can step on it as hard as I want without CEL activation.
2003 E320 123K miles
1999 ML320 248K miles sold
2001 ML320 166K miles sold
2003 Lexus GX470 320K miles
1980 280SE W126 EURO 142mph top speed
mbenz80 is offline
post #6 of 7 (permalink) Old 01-11-2011, 08:42 AM Thread Starter
Quoted: 6 Post(s)
To Witek:
Did 52 MPH cruise 11 min then stop key off. Going back another 13min at 51MPH cruise. No change on the obdii, ie the catalyst is still not ready.
To mbenz80:
Was ready before. No CEL , just an O2 sensor code before I change the 2 front ones.
I tried another OBDII still got the same information. Is it possible I should go to indy to get SDS machine to reset it?
idahombz is offline
post #7 of 7 (permalink) Old 01-14-2011, 11:28 AM Thread Starter
Quoted: 6 Post(s)
Update:
Catalyst monitor ready now!
I did lots 10 min+ 50MPH+ driving these days. Thanks Witek!
idahombz is offline
Oxygen Sensor / Lambda Sensor Voltage Testing cbc atl W124 E,CE,D,TD Class 8 01-04-2011 06:47 PM
How difficult is it to change Oxygen sensor 2 in bank 1? AMGSingh C208/A208 CLK-Class 5 11-21-2009 08:58 PM
how do you change an oxygen sensor row503 C208/A208 CLK-Class 1 02-28-2008 05:30 PM
help on change oxygen sensor echaocn W210 E50 AMG, E55 AMG 1 10-04-2007 10:49 PM
OBDII Catalyst I/M Monitor "Not Ready" elk127 W163 M-Class 0 08-11-2005 07:36 AM
